3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Compact 4 channel firework detonator
I built this recently, basing it off of other designs, and using car wiring methods as my system. this system uses one common wire. usually the positive wire as a common wire with all the switches and each wire being a negative current. to save space i chose to use 2 9 volt batteries instead of the rechargable large 12 volt. i also chose to not use LEDs for sake of saving space
Step 1You will need:
you will need:
all of this can be bought at radio shack for a total of around 30 dollars
mid sized hobby box
2 9v battery holders
2 9v batteries
speaker wire
4 button switches
1 regular switch
6 position wire terminal
1/4 inch diameter bolt and nuts
solder
electrical tape
2 jumper plates for wire terminal
tools:
Dremal tool
Drill
soldering iron
3 comments
Mar 7, 2011. 4:39 AMilovewebkinz says:
can you make a 5 cannle insted
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:G-force777
