I wanted the system to be expandable but I was also pressed for space since I am living in a very small apartment with three other individuals. The final parameters were: the system had to be easily managed and easily transported. Easily managed because I'm sometimes lazy when it comes to upkeep and easily transported because the system is not going to be set up in a permanent residence; I will be moving at the end of the semester. Since my apartment receives very little lighting I decided to make a grow light stand as well. Since grow lights can get up into the hundreds of dollars, this adds quite a bit to the total cost of the project. Although this allows you to put your plants where ever you please, it is by no means necessary as long as you have sufficient lighting.
Remove these ads by
Signing UpStep 1The Containers
Initial Setup:
1 x $3.00 - 3 Pack of Ziploc Screw Top Containers
1 x $1.50 - Length of Aquarium Tubing
1 x $5.00 - Aquarium Pump
1 x $5.00 - Light Timer
1 x $3.00 - Silicone Sealant
3 x $0.25 - Rubber O-Ring
3 x $0.55 - Straight Connector
3 x $0.00 - Empty 2-Liter
Total: $19.90
~ $20.00
Three Addition Containers:
3 x $0.25 - Rubber Washer
Total: $5.40
To make the 2-Liter containers look nicer I scrubbed all of the glue and label off. If you've ever tried to do this for other projects, it's quite a hassle. An easy way to clean the 2-Liters off is to fill them up with hot water and cap them. Next, submerge them in hot soapy water and let them sit for a few minutes. You should now be able to scrub the label/glue off with a coarse dish scrubber as shown in the pictures. The glue and label free tops can now be cut off.
To start the construction of the containers I traced the 2-Liter onto the lid and started to grind away with my dremel. It is important that you get close enough to the size of the 2-Liter while not cutting too much or too little plastic away. If you don't get a big enough hole, the lids will crack when you try to screw the 2-Liter in there. If the hole is too big, you will need to patch up a lot of space. I found these #18 O-Rings at the hardware store. They fit nice and snug around the 2-Liter. The caps need a hole for the aquarium tubing to fit through and the tube has to reach all the way to the bottom of the reservoir. When the reservoir is pressurized, the nutrient solution will be forced up into the plant. To put it all together I fit the O-Rings on the 2-Liters and screw them through the lid, applying silicone sealant to the base of the threads. I then fit the cap on and tighten. You should also smear sealant where the aquarium tubing goes into the cap to prevent an air leak. Next, the straight connectors are cut in half and holes are drilled for them. Sealant is used here as well. Remember that one of your containers will only need one port while the others will need two to pass the air pressure on.
The way this design works, is that each plant has a sealed chamber with solution and two tubes. One for air, the other for solution/water. The solution/water tube goes straight up to the plant/gravel from the bottom of the chamber. The air tube blows air into the chamber, displacing the water, pushing it up through the solution/water tube, into the plant/gravel. When there is no solution left, the air goes though the tube, keeping all of the solution in the plant/gravel. When the pump turns off, the solution/water slowly drains back into the chamber since there is no air pressure keeping the solution/water in the plant/gravel.
I do not know of a way to have one single chamber for the solution/water unless you have a massive container (like an air tight storage container) and each plant/gravel container is on top of it.
Hope that helps.
Algae is also another problem...might want to paint the water reservoir opaque.
One other way to fix this might be by using valves (http://www.petco.com/product/7492/PETCO-Air-Control-Kit-for-Fresh-and-Saltwater-Aquariums.aspx?CoreCat=OnSiteSearch), and perhaps playing with the height of the plants vs. the pump. But I think, as with playing with water levels, it might be difficult to get everything just right, and will likely end up costing about as much as seperate pumps for each plant.
