Step 3Info and Tips on Getting Your Garden Started
Nutrients and pH
I bought this nutrient solution ($11.95), as well as this pH tester ($4.95), at a local hydroponics supply store. The nutrient solution is mixed according to the label and put into the reservoirs. The solution will need to be changed EVERY TWO WEEKS! Failure to change the solution can result in the production of chemicals that are toxic to your plants. This will poison and kill them. Depending on the size of the plants, the system should be "flooded" 2-5 times a day for 15-30 minutes. Be aware that many nutrient solutions come with two or more parts that are mixed in different proportions depending on if your plants are in the growing stage or the budding/flowering stage. The nutrient solution I bought is just for growing since I am growing cilantro, parsley, basil, and thyme and don't want the plants flowering and creating seeds. The pH tester was just a few dollars and is nice to have. If the plants start to deteriorate, the pH can be tested to see if that is the underlying problem. If the pH is fine, you know it has to do with something else. The pH should not be a problem if you buy a nutrient solution since the solutions are designed to have the correct pH for growing.
Lighting and Temperature
If you are using artificial light, another timer should be set to give the plants around 14 or 15 hours of light a day. While seeds are germinating, there is no need for sunlight. However, once the seeds sprout, they will need plenty of light to grow. I also bought a thermometer to monitor the temperature. Many plants have ideal growing temperatures and this cheap, $1.00 thermometer is a good tool to have and will help you monitor the ambient temperatures in your growing area.
Getting Started and Tips
I am using expanded clay ($9.95 for 10 pounds) in my system. The clay pellets rub together in transit to stores and produce a fine powder. They should be washed before use. Before transferring plants into your system, make sure there are no leaks by doing a quick test. I saved one of the bottoms from a 2-Liter to act as a stand when changing the solutions. The more containers that are used, the bigger the pump that will be needed to keep the flooding process going at a reasonable rate. A smaller pump may work but it may also take 10 minutes for all of the containers to flood completely. Also, be sure to check for leaks in your pots. One small leak will greatly reduce the air pressure in your system and drastically slow down the flooding process. One benefit of an ebb and flow system is that the roots of the plants do not grow to be very large since the nutrients is delivered directly to them. This allows for smaller pots and a more compact design.
comments
Add Comment
Dandeman321 (author)
says:
Add Comment
