Compact, Cheap, and Expandable Hydroponics System
Step 4Conclusion and Results
Some Cheap Alternatives
I wanted to go all out and get some real hydroponics equipment but it's not needed. My old system, as stated above, used tap water and just liquid fertilizer (~$3.50) as nutrients to grow an aloe vera plant and did fairly well. Instead of expanded clay, or any other hydroponics media, I just used some aquarium gravel I bought for a few bucks. Instead of buying a light, you can use the sun as long as there is a good location that receives a decent amount. You don't need to spend a lot of money to make your system work. Buying good equipment does provide benefits but it is definitely not needed for the amateur hydroponics enthusiast!
Results
I decided to order some small herb plants online since starting them from seeds taking way too long and is often quite difficult. I got my plants in the mail and transplanted them. The cilantro started to droop and most of the plant died off... but! there was one little sprout in the middle that survived! In a few days it doubled in size and then I noticed more little sprouts starting to grow, so it's coming back to life! The parsley is doing well, a leaf or two started to die off, most likely due to the shock of transplanting them. I was a bit rough trying to get the dirt off the root. The majority of the plant, however, is deep green and looking good. The basil is pretty small but is responding to the light and directing its leaves toward it. The thyme is surviving. No real signs of it flourishing though. I also bought a few small spinach plants but I haven't had time to make more containers for them yet.
IMPORTANT
After I had transplanted my herb plants I noticed that the nutrient solution was not coming up the whole way in some of the pots. This was due to the fact that one pot had less solution than the others, allowing it to push all of its nutrients up into the plant and bubble, releasing the pressure needed for the other pots push the water up. In order to fix this, flood the system by turning the pump on. When one container starts to bubble, add more water/nutrient solution to it. When you add more, it takes more pressure to make it bubble and allows the other containers to fill up higher. It took me a bit of filling up but I eventually got it all evened out.
I hope this is all straightforward!!! Message me with any questions or comments, I love to help!!! Thanks for viewing!
18 comments
Sep 8, 2009. 11:43 PMcoco j says:
do u guys happen to have a more simpler way for me to understand how to make one of these, you know like for dummies? lol!
Aug 31, 2009. 11:21 AMjrossetti says:
This is a pretty ingenious system you've designed here. I suppose there's a theoretical limit in the number of containers you can connect, based on pump output. I've seen higher output pumps, though, with 2 and 3 output nozzles, so I suspect it's possible to have a huge network of containers. This is one of those ideas I'm definitely going to have to try. Thanks!
Sep 4, 2009. 9:47 AMjrossetti says:
Yes, I figured this out too last night. The problem is the low pressure output from the air pump, I believe. It's possible to add a second air pump and put airstones in the base of each of the upper containers, but I feel that overcomplicates the whole system. As it is now, it's simple and elegant - and elegant in its simplicity! I think forcing it to bubble isn't terribly critical in a system this small, and since each plant has its own reservoir, that makes it exceedingly easy to correct any problems with aeration or with the nutrient solution. I've set mine up with 3 plants total: one in hydroton, one in perlite, and one as a soil-based system. I will keep you updated how they all fare.
Jul 16, 2009. 9:47 AMbustedit says:
are you going to Scarborough Fair?? (couldnt resist)
Jun 24, 2009. 6:53 PMjtroc6 says:
I just wanted to say you are the man! never have i seen a hydro system this cheap!!keep doing what you do man.
Mar 28, 2009. 5:29 PMpoppieann says:
Can I use different sized nutrient containers? Say I wanted to use take out containers and they are all different sizes, will this effect the systems ability to pressurize or should I just adjust the fluid in each container?
May 28, 2009. 10:46 PMhilojohn says:
The containers can be wider, but not taller... the air is going to push untill the lowest amount of liquid is gone then because of bubbling it will lose a lot of preassure.
Mar 28, 2009. 6:41 PMbigt4616 says:
i would think it would be fine, unless you dont have any leaks, it would still push out the same amount of water to the top.
Apr 8, 2009. 8:27 AMplowboy07 says:
Could i have just one, Instead of haveing three containers
Apr 8, 2009. 3:28 PMMaxPowers96 says:
Very awesome Best one I have seen so far! Great job keep it up
Apr 5, 2009. 4:14 PMmedcare651 says:
way to go college student!!!
Apr 2, 2009. 7:18 AMLeroy says:
The aquarium air hose just uses air to provide downward pressure on the liquid, right? The liquid does not move from pot to pot. It just stays in the single pot you put it into. Is that correct? Each pot has to be at the same level for this system to work. You can't have one pot sitting on the countertop and another pot sitting on the floor and another sitting on the windowsill. Is that correct?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
37
Author:Dandeman321
