3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Compact Disc Jewel Cube Display Case
A fun way to display artwork, photos, drawings, digital prints, literary musings, mixed media creations, or whatever you like using four easily rearranged CD cases!
Jewel Cube Display Cases require no tools or adhesives and look great when strewn about the home. The cost to create one depends on what you'd like to place within the display areas or whether or not you'll be buying new jewel cases - I made all my cubes for free!
I had the idea for this project while experimenting with a stack of empty jewel cases - just trying to see if they could fit together in some way because I wanted to use them rather than toss 'em out. I must admit I was pleasantly surprised that they'd snap together so perfectly into a cube shape with only a few simple steps.
  • Inner dimension of each display area is approximately 5.25 by 4.5 by .25 inches (135mm by 115mm by 6mm).
Step 1Separating Jewel Case Pieces
Separate the three jewel case pieces and set aside the center CD holder.
  • A relaxed approach is best when separating the pieces so as not to snap anything off and render your case useless.
20 comments
Jul 26, 2010. 5:32 AMorquidea says:
This is very cool! Maybe I can make a lamp from this idea...
Jan 28, 2010. 7:26 AMrightkeyrepair says:
Fantastic!
Jun 16, 2009. 11:50 AMruler challenged says:
Thanks for the instructions, I have a bunch of cases and couldn't think of how to use them, now I do. I will place photos in mine and have a nice display. Keep the ideas coming.
Apr 1, 2009. 7:28 PMHarkle says:
This is made of so much win - seriously! Thanks for sharing.
Jan 10, 2009. 6:05 PMlouiedog67 says:
This is great! I made one of them earlier today and was inspired to use the resulting cube as (ironically enough) a cd storage box. Check it out at my blog..
http://louiedog67.blogspot.com/2009/01/so-this-is-in-its-early-stages.html
Thanks so much for the great technique!!
Aug 27, 2008. 9:52 AMstampez says:
This is such a NEAT project. Thank you so much for sharing the directions and great step by step directions. I made one and posted it on my blog - to use as a Christmas Card holder. You can see it here: http://stampez.typepad.com/my_weblog/2008/08/cd-jewel-case-box.html
Jul 12, 2008. 8:44 PMctt489 says:
I've tried this for hours. You must have magical cd/dvd jewel cases. There is no way this can work without tape or glueing the 90degree pieces together. It doesn't work for me and I'm frustrated
Jul 20, 2008. 11:20 AMctt489 says:
Thanks so much for the details, it helped. I won't say what I did or didn't do in the first place. One problem still remains and that is one side is not as sung. I noticed that one side is a 2cd case but ironically that's not the one giving me a problem. Thanks again...great little box.
Jun 20, 2008. 10:42 AMshyrell says:
A great idea! Just a few more instructions please for people like me who didn't realize at first the it would take 4 cases. (Duh! to me.) ;-)
Jun 21, 2008. 9:07 AMislander_circe says:
No gluing or tools required - that has to be the easiest construction that I've seen to date. Will definitely make some of these. I love the artwork you have displayed in your cases. Where did you get these from? Are they your own work? Either way, they make miniature works of art of a storage item.
Feb 7, 2008. 5:50 PMSurreal says:
This is an awesome idea! I'm gonna try making a base and lid for it out of chopsticks/skewers, in a square slightly bigger than the face size. I was thinking of either lashing together the skewers like a bamboo placemat (or gluing together a row of square edged chopsticks) and then gluing 4 chopsticks in a square on the inside of these mats to make it sit snug into the square opening (if that makes any sense!). I'll glue the bottom "lid" to the base of the CD cases using a glue gun, or something. How's that sound? I'll try and do it this weekend and upload photos. Let me know if you have any suggestions! Im gonna make it as a present for a friend, and fill it with small bags of gummy bears!
Feb 18, 2008. 4:24 AMSurreal says:
Just to update, I did make one. I bought a pair of bamboo sushi rolling mats, cut them into the same square as the CD box footprint and sewed them together at the corners. I then made the CD box as normal, and then attached the CD box to the bamboo base by threading a strong length of wool through the holes in the CD cases (where the tabs stick inwards to place the inlay leaflet). Unfortunately I already gave the present to my friend, but I will try and get photos when I can. :)
Jan 3, 2008. 12:20 PMjpfaraco says:
This is so simple I can't believe it.. Just love these jewel case projects !
Nov 15, 2007. 2:51 PMghicken says:
I recently found a cube similar to this one with about 20 year old photos in it.
Oct 29, 2007. 6:31 AMiraqniphobia says:
Oh man, this, plus a lamp like http://www.instructables.com/id/shoji-style-table-lamp/
or another simple lamp like that would look pretty nice.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
26
Author:totemic
I was born in Minnesota where I've spent the majority of my life, and I've been active in many areas of artistic creation; including sculpture, jewelry design/construction, graphic design, ink drawing...
more »
