PLEASE, PLEASE...... BE CAREFUL!
I am observing only a fraction of the advertised predicted life of 10,000 hours; consequently I decided to investigate the possibility to prolong the life of these complex lamps by reducing their power consumption, which, of course, is also an added bonus to the household expenses. It is a well known fact that less voltage and, therefore, current, equates normally to longer life of any electrical component. The reason is a reduction of power losses typically dissipated in heat.
To test my hypothesis, I used a Variac (pic#0) to test a 100 W equivalent CFL, which consumes nominally 23 W. A Variac is a variable transformer, which allows me to vary the voltage to the bulb. I use a CFL that I bought at COSTCO. The brand is: FEIT “Conserv-Energy”. The technical specifications are:
Power: 23 W (equivalent to a 100 W incandescent lamp)
Voltage: 120 Vac
Current: 350 mA
To my surprise, the bulb lights up brightly at 60 V! By increasing the voltage the light emitted increases also, but not by a significant amount.
Emboldened by this discovery, I thought how to reduce the line voltage without wasting additional power. There are various techniques, each one with advantages and disadvantages:
1. Autotransformer: The most expensive proposition
2. Capacitor in series: cheap, causes a phase advance in the line current
3. One diode in series: very cheap, but causes DC current in the line
4. Resistor: expensive because it wastes power.
I decided to investigate solution 2. and solution 3. I have to add that my line voltage is 125V and not 120V, therefore in order to compensate for the difference I will multiply my power measurements by 0.92 (120/125^2).
Remove these ads by
Signing UpStep 1Capacitor in series
A capacitor is a reactive component that does not consume real power, but only apparent power; its impedance is: Xc = 1/ (2*π*f*C), where f is the line frequency, in USA 60Hz and C is the capacitance, typically expressed in microfarad (μF). The circuit is depicted in pic#1. The waveforms needed to calculate the power is depicted in pic#2. With a 8μF capacitor in series the power consuption at the bulb has been reduced from 23 W to 14.2 W, a net reduction of 38.3%. assuming an average cost of $0.14 per KWh, for a bulb life of 10,000 hours the cost would be: 0.023KW*10,000Hour*$0.14 = $32.20, but with the capacitor, the cost is reduced by 32.6%, that is: $12.30. At this point I need to add a comment regarding the capacitor effect on the line. A capacitor creates a phase advance in the current. The utilities would like to supply power to users without phase shift between voltage and current. Said that, the typical loads of a household are: electric motors, washers, kitchen appliances, etc. which create a phase-lag, being inductive. By using this technique of adding a capacitor, we actually “help” the utilities, by compensating the phase-lag of a typical household with some phase advance! In pic# 3, I show a bank of 4 CFCs all connected in parallel and then in series with two capacitors in parallel (I had them in my electronic junk) for a total of 32μF.
On the web the cost of a starting capacitor 8 μF, 250Vac is around $2-3. The price is not much different for higher capacitance values if multiples of 8 μF is used for more than one bulb.
Your cost savings as calculated at the end isn't correct because not all power consumption is used for lighting. Motors use a large portion of the energy. Fans, refrigerator and Air Conditioners are the heavy users. Using CFLs cuts the cost of lighting and further savings can be gained with your approaches. So good work!
I suspect your CFLs don't reach their rated lifespan because of your slightly higher line voltage, but another source could be voltage spikes from switching on the power to appliances and lights. Whether the capacitor or the diode approach provides longer CFL life is a mystery to me as the voltage spikes would probably be passed by both.
Since motors do consume the majority of electricity in most homes, capacitors could also be used to reduce their reactive power transmitted throughout the house and perhaps prolong the life of your lights as well! That could be your next 'ible!!! Great job!
From my part, I have only a small comment, that is, you wrote: (quote) “Your cost savings as calculated at the end isn't correct because not all power consumption is used for lighting. Motors use a large portion of the energy. Fans, refrigerator and Air Conditioners are the heavy users” (end of quote)
Perhaps you missed my statement in which I wrote that in my calculation I used for lighting only 12% of the electricity used by an average US user.
I have assumed in this work that heat is the source of all “evil” in electronics, therefore simplistically speaking “less heat equates to longer life”, and this is the norm. Of course transients spikes and other disturbances are also playing an important role. I have 14 CFC lights fitted e months ago with diodes or capacitors. On each bulb, I wrote the installation date. So far none has failed….time will tell…stay tuned.
