3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Compact Pegboard Tool Case
Several years ago (16) I moved into a new house and had a young child.  My problem: how to store all of my tools in a limited space in a way that is safe from children.
I built this pegboard tool case which can be closed and locked that gives me about 32 x 4 feet of tool storage space while taking up as little as 11 feet of wall space.
Step 1Tools and Materials
Tools and Materials
Tools:
  Saw for cutting 2x6 lumber, 1x2 strips, and pegboard.
  Screw driver (or drill driver with screw bit recommended!)
  Drill and drill bit (for drilling pilot holes)
  Square
Wood:
  11   2x6 8 feet long
  12 1x2 firing strips, 8 feet long
  4   4x8 3/8th inch pegboard
  1   1/4 inch plywood (good on one side is fine)
Metal:
  2   1/8 inch x 1.25 inch wide x 3 feet long steel bar (for hanging the case
  2   5 1/2 inch angle bracket
  8   5 1/2 inch hinge
  ~100  1 inch long deck screws
  ~50  1 1/4 inch lag screws  (I call these the short lag screws)
  ~50  3 inch long lag screws (I call these the long lag screws)
Other Materials:
  1 bottle of wood glue
You may be tempted to use 1/4 pegboard but I find the 3/8th inch or better is stronger and can take the span I've indicated here without warping.
6 comments
Sep 16, 2010. 9:01 AMmefromliny says:
Great job. Thanks for doing such a great job of taking pics. Mine is about halfway through and it's looking good. I did use piano hinges, because I had some sitting around, and they are holding out very well. Thanks again. Ken
Aug 23, 2010. 12:13 AMgreggspen says:
This is a great idea, just the thing for a workshop with limited space. It could also be put on a wheeled frame for bringing tools close to a job. I think piano hinges might be a tidier option for the doors but I don't know how they would handle the weight. Supercool A+++
Aug 23, 2010. 12:35 AMPresman says:
Great Cabinet You were able to solidify some design for as I am thinking of putting in something like that. Was wondering how well a multi-hinge would work The boards you are using look more like a 1X4 rather than a 2X6. It may be just a frame of reference the picture shows. Can you verify the size?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:maewert
I'm an aerospace engineer by trade but am interested in astronomy, robotics, CNC machines, Arduinos, you name it.
