Compact Spiral Didgeridoo
constructed with readily available and relatively inexpensive modular plastic plumbing... inspired by the traditional Aboriginal instrument, but assembled at the Home Depot!
Step 1Visit your favorite Home Improvement Warehouse
It doesn't have to be Home Depot, but I've found their Aerophones Section.... I mean, Plumbing.... to be rather well organized compared to the competition.
19 comments
Dec 13, 2010. 7:35 AMmarktreefrog says:
It may not be traditional but PVC didges do have a unique and I believe great sound. And when you add the 90 and 180 deg turns it changes the sound. Also resonance chambers for added texture you don't find in a eucalyptus didge. I once made a PVC didge shaped something like a sax that I put up into my djembeand clamped in place. this uses the drum as an amp and you get a percussive blow-back. The clamp allowed me to beat and blow at the same time. Also the slide didge (or didgeri-bone) I'm not saying that plastic is as magical as the original played by an aboriginal master but the world is big enough and music is only made richer by experimentation on the whole.
keep up the good work!
Nov 27, 2010. 2:19 AMpemungkah says:
It's pretty good! Around a middle G on the bass staff without the bell (I was rushed and forgot it). It's certainly a great project to "try out" a didg that's not going to take up an entire corner all by itself when you want to put it away (the problem with my "real" bamboo didg), and yes, it's not a high-priced "concert" didg, but it's definitely playable, and the modular build lets you play around with configurations and length.
Have you seen http://wethome.x10.mx/wdidge/didges.html ? I'm going to try a couple of those after I find all the parts - there are enough odd little pieces that my Home Depot doesn't have that I couldn't pick up the parts for one of those tonight - but they did have the ten elbows!
I'm going to try adding a couple more turns, possibly with some 2" elbows - I'd like to get it down about another 5th or more. One other suggestion I've seen is to roughen up the interior some to darken the tone a bit with a coat of wood glue and sawdust (which I'm pretty sure you could scrounge from the Home Depot if you asked nicely).
Nov 23, 2009. 8:32 PMmike patterson says:
once saw an ABS didge with an old Washer agitator on it as a bell--LARGE
Jul 23, 2008. 8:38 PMkarlito1118 says:
Hi, I made one of these about 13 years ago and had a great time with it. I used a mixture of 90 and 45 degree joints, glued them in sections of 4 or 5 joints each, and interspersed the sections with single joints. That way I could keep the thing together, play around with the shape, and also vary the length/pitch of the dij with different combinations of sections and singles. I think I used about 26 pieces in all and wound up with a VERY low tone. Most impressive in stairwells and parking garages.
Jun 5, 2008. 9:23 AMincorrigible packrat says:
I gotta know... Do you take the assembled pieces to the cash and have them scanned like that? (would be a real larf, if you cement it together in the aisles and have them run through the half used jar o' solvent too...) I've noticed that one can produce vaguely didge-ish noise from those 6363636363636363636363+9 (darn cat) shells of the elusive cardboard snail, as discussed in the "Kiteman's Konch" comment area. Regarding the shop-vac hose. I used to have a toy that was a plastic hose that you spin real fast and it makes a "whoooo-whoooooooo" kinda sound. Might be interesting to didge-ify into one end of the hose and spin the other end around...
May 20, 2008. 7:09 PMSgt.Waffles says:
ABS and PVC didges sound terrible. At least do a bamboo one with a beeswax mouthpeice, if not traditional eucaliptus or even teak in a pinch.
May 27, 2008. 8:00 AMdrummonkey92 says:
didgeri-snob
May 28, 2008. 5:28 PMSgt.Waffles says:
Age 5 years please.
May 30, 2008. 2:22 AMdrummonkey92 says:
haha
May 21, 2008. 7:47 AMTransquesta says:
NO project in which YOU (or others) gain enjoyment or understanding is a "waste" of money, time, etc. That said, when you make such efforts available for public scrutiny, you should be aware that they WILL be scrutinized. It wouldn't matter if you'd built a new cure for cancer out of a radio set or a flawless scaled replica of the Tower of London out of toothpicks--somebody's BOUND to have/offer a criticism. :-)
Dec 27, 2011. 1:29 PMFragite says:
I love how Waffles left the second he gained more than one person opposition.
ONTOPIC: Thank you so much for this tutorial and idea! I'm gonna go and make it now. I am thinking of ending it with a [insert very large diameter here] - 2" bell reducer to amplify the sound AND make it look totally badass.
Also, instead of using that weird bushing reducer for the mouthpiece, try using a bell reducer. Personally, I think bell reducers look much more attractive on PVC didgeridoos than bushings, but I dunno about you.
May 19, 2008. 10:22 PMTransquesta says:
Hmmm. I guess this is a pretty cool idea . . . provided that one knows how to 'play' a didgeridoo and doesn't mind spending upwards of fifty bucks on fittings. How about a Shop-Vac hose instead? ;-) . . .Oh, and how much does this instrument weigh once fully assembled? I'm betting somewhere around five pounds. You could re-title this instructable as the Compact Curl Machine/Spiral Didgeridoo. ;-> Just yanking your chain, dude. I like the idea. It gets me thinking about other PVC projects (which I've yet to complete).
May 21, 2008. 7:40 AMTransquesta says:
Sarcasm, yes--definitely. I thought I'd been clear on that point. :-) BTW, I checked out your shop-vac jet. VERY cool!
May 19, 2008. 11:32 PMPatrik says:
Actually, playig a didge is pretty easy. Playing it *well* is a lot harder, but It's a pretty easy instrument to pick up.
May 19, 2008. 11:39 PMPatrik says:
Very cool! We actually have two ABS didjeridoos, that we bought from a self-proclaimed "houseless" guy in Albuquerque for 20 bucks a piece. He would just take a straight 4-5ft black ABS pipe, and heat it over a campfire to mold it into a more natural shape. Looks great, and sounds much better than a straight pipe.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:psychopathicdude
psychopathicdude is one psychopathic dude, dude....
