Remember to rate it if you like it!
I must say, thank you all for making this THE highest rated survival kit instructable on this entire site! Thank You All!
Remove these ads by
Signing UpStep 1Materials Needed.
Whistle
Chemical light stick
Emergency Candles (optional)
Small LED keychain flashlight
Tinfoil
Piece of paper
Duct tape
Bic pen
Razor blade
Box of WATERPROOF matches
Water treatment (for example iodine or chlorine. I use drops i bought at Coast Mountain Sports)
Poncho, OR a space blanket. (I used a Poncho because it doesnt rip as easily, although this sacrifices space.)
Sorry but this is wrong, shelf life on lightsticks is about a year, and yes I know they can last along time too. Oxygen depletes them (that’s why there in a foil wrapper). Also cold will slow down (Dim) or even stop the chemical reaction. Hold it next to your body if cold, to warm prior to snapping. Also there are two types of lightsticks the regular long lasting, 6-12hrs and Hi-intensity, about 30 min, but at least twice as bright! (Better for signaling!)
Thanks!
Good info So far
The reason behind this is that toward the violet end of the spectrum the colors have shorter wavelengths (higher frequency), and therefore more energy is required to produce those colors of light. T1ZKeR in his earlier comment had the theory right, but had the wavelengths backwards. He is correct in that the higher-frequency colors penetrate better, and so can be more easily seen in less-than-clear conditions.
In most outdoor situations, you'll find a lot of green foliage, depending on the season. A green light illuminates this best, and the further a color of light is from the color of the surrounding terrain, the more poorly it will illuminate it, for the most part. In the dark, you'll find that red illuminates poorly compared to the other colors, which is a reason why it is often used when one wants to preserve their night vision.
I find that yellow is the best blend of visibility, illumination, and runtime, as it tends to last 8 or 9 hours and is quite bright. It would definitely be my choice in a survival situation.
so put a bit of tape on the edge...
patrick
armageddonoutfittersonline.com
You can now get durable emergency blankets at camping stores, much better than the mylar films and orange on one side, they serve multi purposes as heat reflectors, rain protection, signaling, even water carry.
Dental floss makes better snares (imho) and is in a easy to carry spool. (I get some that are the size of 4 nickels stacked up.) I like the idea of the aluminum foil.
This is truly a great kit. The only thing I really see missing is grey matter. A person should know how to use it all before ever needing it. The FM21-76_SurvivalManual is one such place to start.
Red light wavelengths (think infrared) are the shortest light wavelengths visible to the naked human eye. In saltwater, for instance, they penetrate the shortest distance before appearing 'black'. (On average 30-40 ft)
UV, ultraviolet, from the other end of the spectrum, penetrates the deepest.(Over 70 ft usually)
This, and the fact we don't usually encounter purple lights, suggests that UV or purple/blue/green light would be more effective as they penetrate further and are less seldom encountered by most folks. (At least outside of the local bar/cathouse areas ;)
And to add to earlier observations, if signaling at night, any light swung in a circle is considered an SOS by most aviators.
Just my $0.02
Very True!! Also Fire or the smell of fire makes the Lions, Tigers and Bears, as well as a mutitude of other criders uneasy and will make them less likely to bunder into your camp! (Oh My!)
They can also add burning time (wax(fuel)) to your tinder if your kindeling is wet or green.
Thanks
I used to keep a Garrity on my keychain until I discovered the Photon II, which I wear around my neck on paracord. I'll never waste my money on a Garrity keychain light again.
The only drawback to the Photon II is it's tiny size. I have large hands so I sometimes find it difficult to hold.
you can get 10 micro lights for under 5 bucks on that site, i have 20 of them and they are great, i have them on the zippers of all my packs and camping gear and also in all my key chains.
Mine are slightly dimmer, and the on/off switch doesn't always work on one of them.
Otherwise, for the money, you really can't beat it. That is a great deal, 10 for under $5. Thanks.
I think I paid $3 for 2. Gun Shows just aren't what they used to be.
Stephen Markas
Editor In Chief
Survival Kit Reviews
