What is a Question?
Questions are a super-easy way to get answers from the Instructables community. Learn how to build, do, or make anything! You just ask a question and the community will provide answers. You choose the best answer!
Submit a Forum Topic! The forums are the place to ask questions, share a cool project from another site, find collaborators for your latest project, or discuss anything of interest to the Instructables community.
Do you have a lot of images to upload?
If you prefer to upload your images before you submit, then this is for you.
Remember to tag them so they will be easier for you to find when you are viewing your library.
You can also upload images when you are creating your posts.
Did you find a bug or have a suggestion for us?
We appreciate all the help our users give us in tracking down bugs and making the site better for everyone.
PhotosPhotos
If there is one thing that you should take into the wild, it's a knife. While a lot of knives are quite bulky and big, a razor blade is small, and very sharp. Although it has no handle, you can always attach it to one, but often enough you are doing something very small, such as whittling notches into a stick, so a handle may not be needed.
you will probably use you knife for so many other things and when you need an extremely sharp blade you will have dulled enough so that it will not compare to a razor blade.
actually....you'll want to use a bit of duct tape to cover the top piece. I use razor blades..from a razor(so its prolly different?)...to cut random stuff like foam board and paper and what ever. but i would press down on the edge too hard and get cuts on my fingertips....
Why not use one of those razor knives that have the snap off blade. As it get dull, you snap off a fresh edge. it comes in a handle a bit bigger than a hefty pen.
They're sharp,but as robear suggests, they will go blunt, and they break easily. I'd only use one as a compass, magnetize a razorblade, thats suspended in the centre by a piece of string.
I personally drilled 2 holes in the center-line of the blade, and included a coiled bit of wire coat hanger. That way, I can make a handle by looping the wire into either side and wrapping around. Makes it much easier to use, especially if/when you need a bit of force (striking flint for example). I'd suggest including a small pliers or something to make it easy; that's the only addition to my kit.
so put a bit of tape on the edge...
