Complete Stencil Tutorial Using a Free Program by JoshuaTerrell
Featured
A tutorial on making a stencil with an open source program called the GIMP.
I looked on all the Instructs tagged with stencil, and not one gives a step by step for making a stencil in my favorite open source photo program The GIMP.
Step 1: Materials and GIMP
-What You Need-
-printer
-craft knife
-The GIMP
-surface to cut on (self healing mat)
-spray mount (optional)
-spray paint
GIMP is an open source raster based graphics editor. It was designed to replace Photoshop.
You can get it here. gimp.org
Install it, open it up, and familarize yourself with the interface for a bit. Done? Good. Isn't open source great? Didn't cost a dime!
Step 2: Pick an image and open your picture in GIMP
Pick a good simple image (remember: simple equals less cuts) preferably on a white background. This can be hacked by simply erasing around an image in MSPaint or what have you.
I chose a tasteful Stormtrooper sculpture to stencil. Nerdtastic!
Step 3: Crop it
Crop out the parts you want to make a stencil of with the Crop/Resize Tool (Tools>Transform Tools>Crop).
a. GIMP allows you to save a copy in case you want to use the uncropped-unedited image later. Save the copy, then go open the copy in GIMP. (File>Save A Copy)
Step 4: Simplifying the image
We need to simplify the image now. We will do this by Colorify-ing the image. There are two ways of doing this in GIMP.
a.One way is to go to (Tools>Color Tools>Colorize). If you use this method, you will want to set the Hue and Saturation to 0, and adjust the lightness to fit the image (this can be done to taste, generally you want about an even light to dark for a stencil.)
b. The other (and redundant) method is to go to Filters>Colors>Colorify, and select your color (you'll be selecting white).
Both methods are pictured, I chose to use the filter.
Step 5: Tweaking the Contrast and Brightness
Now I'm going to tweak the contrast and brightness a bit. (Tools>Color Tools>Brightness-Contrast) I'm trying to get a hard line on the helmet, the hardest part on this image to keep intact.
Step 6: The Threshold Tool
Next I use the Threshold tool (Tools>Color Tools>Threshold) You'll want to play with the settings to get good hard black and white , which is perfect for stenciling.
Step 7: Stencilable Image
There you go! You end up with a semi usable image.
The key to stenciling is to editing out the "islands" of white in your image. You can make little bridges for them if need be. Once again this can be accomplshed in whatever bitmap editing program (MSPaint) you have lying around. I think the image I have can be edited by hand, so I'm going to print it now.
Step 8: Get ready to cut
Get your craft knife(s) and you image and get it all ready for slicing and dicing.
Step 9: Outline your cuts (optional)
If you have a fairly low res image, this is a good idea. Silver sharpie.
Step 10: Cut and Spray
Once your done cutting, it's time to spray. A simple one layer will do (you could make a 1.5 layer but that's a different tutorial)
As for spraying.
A guide to cutting stencils
• Think from outside the box.
• Collapse the box and take a fucking sharp knife to it.
• Leave the house before you find something worth staying in for.
• It's easier to get forgiveness than permission.
• Spray the paint sparingly onto the stencil from a distance of 8 inches.
• Be aware that going on a major mission totally drunk out of your head will result in some truly spectacular artwork and at least one night in the cells.
-Banksy
Have fun!
1-40 of 111Next »
elementrider says: Sep 18, 2011. 12:44 PM
how did you blow up the image?
HuntingWabbits says: Jul 22, 2011. 6:22 PM
Threshold doesn't work :/ My image comes out pixelated
skyhawkes says: Jun 20, 2011. 4:30 PM
My God man!! This is a giant help and I think I love you... just sayin'... and thank you so much for using GIMP. I fell in love with it like 2 years ago but I never knew I could make a stencil with it. That was stupid easy.
JoshuaTerrell (author) says: Jun 21, 2011. 6:17 AM
No problem. :)
ilpug says: Jun 2, 2011. 9:52 PM
Nicely done. i will check out the GIMP. Can it do something that a high-levcel Photoshop program cant? cuz i have one and it works fine.
BkrevWlevqe says: May 8, 2011. 1:56 AM
Thanks a LOT for this i'ble man!
!revenge! says: Dec 23, 2010. 6:13 AM
hi i have a question about the spray painting itself,
i made a stencil a while ago and i wanted to test it before spraying it to my old guitar. but this is what happened: after testing the stencil, the paint caused the paper to curl up.
do you have any idea how i can prevent this the next time i do this?
greets,
Jelle
ps.
my English may be not very good because i am from the Netherlands and i am 14 years old.
CerealKiller says: Aug 8, 2008. 5:28 PM
Here's Mine: Just can figure out how to print it.
DavidKaine says: Dec 10, 2010. 10:58 AM
Nice. The other side of the helmet (if this is the one from Full Metal Jacket) would have made for a nice ironic stencil, too.
zs says: Apr 13, 2010. 4:55 PM
ctrl +p
rasta_bhoy says: Aug 18, 2008. 7:54 PM
I don't even print mine. I just use my laptop's LCD screen and I would tape the bond paper on it and just trace on it. That's if you have access to an LCD screen. You also skip the outline and printing part too.
zatla says: Aug 3, 2009. 11:05 PM
Haha I tend to do the same, I also use a piece of thin transparent plastic in between the paper and the screen. (A4 fits very well on 15,4") Bless!
mhkabir says: Aug 28, 2009. 6:32 AM
Don't pixels get stuck on the screen?
theRIAA says: Dec 24, 2006. 5:34 PM
nice! if you are doing a face or something tricky you may want to try out changing the hue or color of the image to greater tune in details when its in B&W (adjustment layers in PS is the only way i know how to do this)
such as:
http://dpchallenge.com/tutorial.php?TUTORIAL_ID=43
(before stencilizing it)
92033 says: Jun 8, 2010. 6:33 AM
3-1/2 Years Later :-) (just discovered this)...THANKS For Posting the URL. GREAT STUFF.
Russian sniper says: Feb 22, 2010. 11:01 AM
Charles IV says: Jan 17, 2010. 9:19 AM
Here's mine:
PKTraceur says: Feb 26, 2009. 5:49 PM
Anyone Guess how long? I did this with ONE very sharp pocket knife, cutting it on top of about 20 more papers. Nearly 2 HOURS. The result was kickin' though!
PKTraceur says: Feb 26, 2009. 5:50 PM
-RoAr
PKTraceur says: Feb 26, 2009. 5:52 PM
-Roar
Grr....
PKTraceur says: Feb 26, 2009. 5:55 PM
Here is what it's based off of...
volquete says: Sep 6, 2009. 7:17 PM
w00t! parkour rox!
bvulgarin says: Jul 22, 2009. 7:23 AM
Very useful, thanks!
soongone says: May 19, 2009. 7:39 AM
Thanks it was easy to understand
slimguy379 says: Aug 6, 2008. 1:34 PM
hello great job... this isn't Really about this instructable but though you could help... I currently have a screen printing business and I'm trying to make a 3 - 6 color shirt.. is there a way to separate each and every color? (using gimp, word, or publisher?) the response would be greatly appreciated...
Maxinama says: May 4, 2009. 11:13 AM
It's really easy to do just go image>mode>indexed, select the amount of colors (white backround will count as color) you want and click convert.
stevedem says: Dec 12, 2008. 1:05 PM
yeah, you can select each color and separate each one as it's own layer.
robbs says: May 1, 2009. 12:53 AM
I tried to change the color of my stencil using "select by color" but it remained black. What am I doing wrong? Thanks for the input.
ericgay says: Mar 21, 2009. 9:06 PM
NICE!
fwjs28 says: Feb 26, 2009. 4:56 PM
woot!
PKTraceur says: Feb 26, 2009. 4:39 PM
If it's any help, and your colours are inverted, try colours
runkrocker says: Mar 28, 2008. 1:17 PM
cool instructable! vey vey helpful. i dont fully know all of what photoshop and gimp can do and this was awesome. i made an invader zim stencil. yay!!!
PKTraceur says: Feb 26, 2009. 4:03 PM
GIR!
patycuack says: Mar 29, 2007. 6:47 PM
what do you think about this one i made minutes ago... first try, i think its not well done..
cornflaker says: Jan 12, 2009. 9:36 PM
It's quite good if you can actually cut it out...
master-of-chaos says: Jun 3, 2007. 8:37 PM
its good but u need to sure up some lines, smooth it out
JoshuaTerrell (author) says: Apr 1, 2007. 3:01 PM
haha, not bad at all, I'm glad to see evryones getting in the act
eat_squids says: Dec 25, 2008. 2:29 PM
Yeah...here's a couple i did. Hope you like them/
eat_squids says: Dec 25, 2008. 2:32 PM
For some reason they didn't post...here they are for real =)
1-40 of 111Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
