3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Compost Screen
Compost Screen
This is an instructable for how to build a simple compost screen out of redwood and hardware cloth that can be used to sift foreign objects out of your compost or potting soil. It takes about 15 minutes to assemble and can weather the elements outside.
Step 1Materials
Materials
The compost screen is built from:
  • 2"x2" redwood stock (I prefer to build with cedar for outdoor applications since it is more abundant than redwood, but not all places carry it in California)
  • hardware cloth (This is like chicken wire. You can get it in 1/4" or 1/2" mesh. I used the 1/2" mesh so it will sift quicker)
  • staples
  • screws
You will also need the following tools:
  • chop saw (I used a chop saw to cut my frame but you can also use a hand saw with a miter box)
  • drill with bit and driver
  • hammer
  • tape measure
12 comments
Mar 24, 2012. 11:40 AMracoontnn says:
#20605@!. K =5 1C45B5 2>7@060BL, 5A;8 O 8A?>;L7CN 0H <0B5@80; =0 A2>5< A09B5 2 @CAA:>O7KG=>9 7>=5, 2 ?5@52>45?
Jan 2, 2012. 9:18 AMrobert1959 says:
I built one of these also, but I added an additional screen. The top screen has the 1/2 inch spacing and the lower screen has the 1/4 inch spacing. The screen frames were built similar to the author's screen above. I put about a 4 inch spacer between the screens. The first screen removes large items and the small screen removes the rest. I do have to tip it unfortunately, but it yields some very fine compost. Our community has a recycling center for twigs and grass. They will compost this, however the product is not very good until it is sifted. I was toying with idea of creating a rotating sifter. Same concept with using screens, however it would be in a tube form and tilted on about 15 or 20 degrees (or more, what ever ends up working). You would rotate the tube while someone else shovels in the dirt. As the tube rotates, the finer material falls through the screen as the larger stuff makes it's way to the other end of the tube and falls out. A bit more complicated as a stand would need to be made for the rotating tube, however I believe the throughput would be much greater. Depends on how much compost one needs to sift.
Dec 26, 2010. 6:20 AMcompost screen says:
I've made screens like this for years but believe that I have an ergonomic improvement and a suggestion for an easier frame. In this design the compost is put into the frame the stuff that doesn't sift through is trapped inside by the frame edges. The user must then tip the sifter to get out the trapped large pieces (that will tire you after a short time). It is better to build a frame and put the hardware cloth over the top. The weight of the material on the hardware cloth will cause the cloth to bow slightly leaving enough of a rim around so that it stays on the sifter but when only large particles are left you can simply push the material off of the edge, no lifting required. I use the backside of a garden rake to work the material back and forth. Next, no need to make miter joints, simply use 2x4s and make butt joints. Nail through the short dimension. Then, as stated previously put the hardware cloth over the top. Now, if you think ahead you can make the frame fit over the top of either: a wheel barrow, a mulch trailer, or the frame of a raised bed. I have all three -- and now plan to move onto the ultimate compost screen as my next project. Here is the nicest design I've seen on the web: http://www.flickr.com/photos/laj2006/541061869/sizes/l/. Basic construction here: http://www.instructables.com/id/Trommel-Compost-Sifter/
Jun 3, 2010. 5:17 AMpfred2 says:
 When I make these I use glued and screwed lap joints. They're easy to make, and about as strong as it gets. Lap joints might not be quite as pretty as miter joints but I'm not hanging mine on the wall either.
Maybe the next one I make I'll try making a mitered lap joint. A bit tricky to execute, but it'd be the best of both worlds. Then again, my lap joints don't really kill me in this application.
Jun 3, 2010. 5:02 AMpfred2 says:
I've had similar and while it works it is time consuming and labor intensive. While watching a number of documentaries featuring archeological digs I kept on seeing a similar sifting design repeatedly where a sifter is suspended. So I made one and it works great. Next to a power tumbler this is the way to go.
I throw a wheelbarrow under mine, then 3-4 shovels of material on top, a few shakes, tip, and repeat. 5 easy minutes and I have a full load of black gold! The wires do the work.
Jun 20, 2009. 1:45 AMhv3333 says:
We've been wondering about building something similar to help turn our heavily compacted former farmyard into something that plants can actually grow in. As you can imagine, we have quite a large volume to sift for stones, glass, random rusty nails, & slate slivers (mmmm, all lovely & sharp), not to mention sifting the additional organic matter we plan to add. Our (not yet constructed) idea was to suspend the sifter on thin rope from a frame or tree so it swings freely and all our effort could go into shaking the sift rather than holding it up.
Feb 10, 2010. 12:10 PMComposto says:
 If you built something workable, I'd like to hear.   I've seen sifting screens in tv documentaries re: archaeology, and interest is keen.  Share what you have learned, please.
Composto
Aug 17, 2009. 3:01 PMJust-Mike says:
Great Instructable! I built one of these today so I can remove all of the rocks out of my garden plot.
Jun 4, 2009. 5:30 PMNorm Pro says:
Built it ! Everything worked great !!! When lifted the bucket with dirt in it the handles pulled off !! Doh !!
Jan 7, 2008. 9:04 AMcompletegeek says:
Great instructable. I plan on modifying it a bit. I'll be using a smaller mesh (probably about 1/16 when I go diamond hunting at Crater of Diamonds State Park in Arkansas.
May 24, 2007. 10:11 PMGmastefluffy says:
Agreed , kudo's
May 24, 2007. 6:45 PMHamO says:
Very well done, useful instructable and great pix. Good job.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
875
Author:noahw
Editor of the Workshop and Outside channels...I'm back!
