3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Compost Tumbler
Compost Tumbler
I'd been looking at these fancy schmancy compost tumblers online as I'd gotten tired of turning my compost pile. There were 2 big detractions from these prepackaged tumblers; 1- too expensive for my penny pinching ways, and 2- they all sat way up in the air making it quite difficult to rake and shovel material in and out.
This looks to solve those two issues.
Step 1Materials
Materials
1 55 Gallon Barrel (preferably one whose previous inhabitant was not poisonous)
1 3 Ft. x 18 In. Board
4 Bricks
4 NON Pivoting Wheels
2 Pivot Hinges
2 3 In. Pin Locks
Tools
Drill
Cutting Implement (I used a miter saw)
80 comments
1-40 of 80next »
May 22, 2012. 2:54 PMdrpaula99 says:
I am building this compost bin today using 2 skate boards mounted on a plastic pallet. I AM EXCITED. So far so good. Thanks for all the great additional ideas (for me, needed). Got the barrel from a craigslist ad ($10) and the skateboards were free from a trash can after a yard sale. I am sure my neighbors will appreciate looking at this rather than the ugly black round hard plastic one. I am going to put a flexible plastic pipe wedged from opposite "sides" for a stirrer.
THANKS again.
May 11, 2012. 6:53 AMLancePenney says:
I see it's been almost five years since you've posted this instructable. I'm wondering if you've had any problems with the wheels rusting and siezing up on you? Great job by the way.
Sep 19, 2009. 1:48 PMweedsl1951 says:
You can go to a car wash and pick up the barrels for "free". But best to call first. I picked up 6 barrels last year for free.
May 21, 2011. 3:44 AMrmalen1 says:
My barrels came from a car wash and had sodium hydroxide in them. How do you neutralize sodium hydroxide and ensure that it doesn't contaminate your compost and ultimately kill the plants your using the compost on?
Apr 1, 2012. 6:16 PMBrynhildur says:
Empty out as much as you can. Wash it out with plenty of water (wear gloves and goggles and long sleeves) let it go down the drain. Sodium hydroxide is basically a drain cleaner and it is easily soluble in water. Be careful not to get splashed. The water may heat up a bit.
Aug 27, 2011. 11:53 AMpapabear108 says:
I know you have already found a solution to your problem but I have a suggestion. I own a pressure washing company and use sodium hydroxide to restore wood. I use vinegar to neutralize the product and then I wash it with a car wash solution. It has worked for me. I am not sure if that is enough acid to neutralize for the purpose of compost. I would suggest lime in the compost mixture but again I am learning how to compost for my yard so I may be wayyy off the mark. I hope this helps.
bear
May 27, 2011. 8:09 PMwushuair says:
Use an acid. While I'd suggest HCl (Hydrochloric Acid), it's not really at your local CVS. Acetic acid could work if enough of it is used, that is, vinegar. Acid + Base (NaOH) will result in a relatively harmless salt and water, depending on your conjugate/neutralizing agent.
May 28, 2011. 2:34 AMrmalen1 says:
I used a gallon of apple cider vinegar. Does that sound like enough?
May 28, 2011. 8:00 AMwushuair says:
If you poured it in and then coated the sides with it to neutralize the NaOH, I think that should be plenty. While I can't seem to balance the Chem eqn, this is what I suspect:
C2H4O2+NaOH -> Na2CO3 + H2O.
Na2CO3 is sodium carbonate which is an irritant: http://en.wikipedia.org/wiki/Sodium_carbonate. Otherwise, it should be OK. Just wash everything out with water afterward.
May 28, 2011. 1:59 PMrmalen1 says:
Oh yes. I had blancing the alittle trouble balancing the equation myself? LOL! Thank You for the info. I gave it a good vinegar bath and a water rinse.
Aug 29, 2011. 5:14 AMryckmans_t says:
vinegar (=diluted acetic acid) neutralisation has this equation:
CH3CO2H + NaOH --> CH3CO2-Na + H2O
wash your drum with water a couple of times, then a couple of times with vinegar.
NaOH is corrosive but will get neutralized by your compost eventually, so i is not going to kill your plants, unless you have a lot of it. You can get a cheap pH testing kit from any garden center if you want to check.
best Thomas
Mar 25, 2012. 2:30 PMguynoir says:
I love the design of this. I just built mine last week. I filled it up about half way and found that the compost did not turn but simply slid down the interior of the plastic barrel. (perhaps this is because I have an abundance of pine needles in my compost?) To fix this I drilled some holes and screwed a few bolts in so that they stick up inside the barrel about a half inch. (I feared that using screws might result in a nasty gash in my hand while trying to scoop out the compost.) This gave the compost something to "catch" on while turning and now the compost flips over nicely.
Mar 5, 2012. 4:06 PMgardenlvr says:
How have the wheels held up? my concern is the weight of the barrel on such a small surface? When the barrel gets heavy will it still roll? I am checking these out to make one of my own and I am trying to avoid mistakes in the construction process. I must say your design is one of the simplest :0)
Dec 23, 2011. 4:21 AMkyriaap says:
made one myself as well. just made some enhancements. got some more aeration holes on the side and included a computerfan pointed to the holes on the long side of the barrel. since we are in the middle of the winter right now, no heat has been produced unfortunately :( don't worry about the flammable sign though, i burned the last bits of car brake fluid out and washed the barrel afterwards.
Dec 23, 2009. 11:00 PMgarywpalmer says:
I finished my composter this weekend with a few modifications.  I used roller skate wheels ($5 pair of skates from Goodwill) on a 1 1/2" PVC pipe stand.  It's working great!  I've had composting material in for 3 days and it's already getting warm.  Of course it doesn't hurt that I live in Phoenix, Arizona, land of mild winters.
Aug 3, 2011. 11:31 AMdense says:
What are the dimensions (length-width) of your pvc frame? How tall are the legs?
Jun 22, 2010. 8:52 PMconfuscated says:
How did you affix the wheels to the PVC pipe in a manner that it supports the composter's weight when full? Looks like a great design!
Jun 23, 2010. 1:29 PMgarywpalmer says:
They are monted with 1/4" bolts and nuts in such a way that they are hieght adjustable. I have since moved them out closer to the edges of the barrel where the plastic is much thicker. See the close up for bolt an nut arrangement. Thanks for the comments. It's been working great.
May 27, 2011. 8:17 PMwushuair says:
Does the type of barrel matter? I would suspect that certain types of plastic would be prone to leach VOCs or BPA, and that metal ones would not only be harder to work with but also may rust? Any tips/Comments/concerns?
Dec 2, 2010. 3:19 PMgemtree says:
I like these ideas for the kind of barrels that have no unscrew lid on top. But I searched the internet til I found food barrels that had a screw off lid and roll them on the ground to 'stir'. I bought a few of the nonscrew top barrels and will try an end loader. I think having two or three would keep them from getting too full and discharging from the end when I open it. I have found that even if it is pretty full, I can still stand the screw top barrel up so am thinking I can get away from building a roller. What can I say? I am lazy!
Jun 23, 2010. 9:10 PMconfuscated says:
Thank you for posting this. It's exactly what I was looking for. One question though: about how much would you say that the composter weighs when full?
Jul 11, 2010. 7:28 AMwhejas says:
I picked up one of these barrels from work. When it was full of corn syrup, it weighed 600 lbs. Compost isn't as dense, but I would plan on it weighing at least 400 lbs when full for support purposes.
May 12, 2010. 2:56 PMjfaurschou says:
I built mine on your design and it's working very well. I made the door longer and narrower, Perfect size for my mower bag to fit up against to dump, as well as a good size for a shovel/rake to get stuff out. I keep a small metal tub about the size of a flower pot in the kitchen for kitchen scraps and so forth, and the whole family is getting into this as my boys (7 and 9) love being the ones to empty the tub into the bin each day, and they fight over whose turn it is to roll it. Thanks for the idea!
Apr 5, 2010. 4:14 PMdepotdevoid says:
Nice one!  I picked up a barrel today and plan on building this later on in the week.  Thanks for the great instructable!
Mar 31, 2010. 8:28 PMglindow says:
I have been getting my barrels from a local Dairy.  They cost 3 bucks but that's not a big concern.  Now I just need to find the right wheels.
Jun 8, 2008. 2:24 PMRahdzhillaxxx says:
What would be some types of "waste" to avoid, and what kinds of additives are best? I plan to use grass clippings and veggie trimmings from the kitchen.
Feb 13, 2010. 7:25 PMnearyjm64 says:
check out this website about what you can and shouldn't put in your composter.  http://www.epa.gov/waste/conserve/rrr/composting/index.htm
Nov 14, 2009. 5:38 AMDave G says:
I did a very similar project but I used a spindle instead.  Works okay, but I put too many holes for aeration, which I need to probably fill in now.  You can see mine at www.goodrumfamily.com/compost_tumbler/index.html
Feb 1, 2010. 7:59 AMDave G says:
messed up that link.... it should be  www.thegoodrumfamily.com/compost_tumbler
Sep 1, 2009. 12:23 PMDanYHKim says:
This is very nice. Using external wheels simplifies the design greatly, and I'll use the recommended 4" wheels instead of smaller ones. I came upon four plastic barrels that were being discarded, so I can afford to experiment, but I'd like to have two working composters, one to have finishing compost, and one for starting compost. That way, I won't be putting fresh kitchen peelings into compost that's about to be decanted. I will probably not fill the barrel more than six inches, to keep it from becoming too heavy to rotate easily. In addition, I hope to leave the side open, so I won't have to devise a door. Still thinking about how to remove the finished compost without hurting myself. Having the assembly close to the ground will probably help a lot, though.
Dec 20, 2009. 12:38 PMkoubis says:
That is actually better design what you have just described. You do not need much for aeration, leaving just couple of smaller holes will be enough. The aeration happens as you turn the drum. Side opening is better as  you can easily remove the finnished compost when it is done. You simply lift the drum on the other side and "pour it out". So just get smart clips for the opening or even make door on the lid for getting material in. I will be designing mine this way during spring and will post the pictures later. I love the neat design of the external wheels as well. I will be using 200l steel drum.
Oct 23, 2009. 12:42 PMdrawe21 says:
If you leave the side open you will spill out the contents every time you turn it.
Aug 30, 2009. 1:56 PMgarywpalmer says:
This is great! Just last week I happened to drive by a business and they had the same blue barrels outside with a sign, "Barrels $5 each". I'm going to build this but I'm also going to check some thrift stores for a couple of cheap skate boards. I think the wide skate board wheels would be excellent for this because of the trucks the wheels are mounted, the ball bearings and the wide width. Thanks for the idea!
May 28, 2008. 8:48 AMjamiefunk says:
What about placing the door on the end of the barrel instead of on the side? This would keep the barrel from warping around the door, and would make the whole structure more stable.
Aug 20, 2009. 7:40 AMalexholman says:
I made one of almost the same design with the door on the end. What I didn't realize is that it makes filling really hard once the barrel is over 1/2 full. Stuff tries to fall out the door as you're putting it in if you can't roll the door up onto the top. To fix this, I ended propping the end of the whole structure on some cinder blocks so that the barrel was angled down at about 45 degrees. Not the best solution, but it works for now. Once this batch is done, I may try to re-engineer the wheels to better support a 45 degree angle barrel.
Jun 21, 2009. 8:58 AMminime12358 says:
Where Could one find a 55 gallon bin?
Jun 22, 2009. 9:10 PMkaro1039 says:
Check with your Coke or Pepsi bottlers, they use plastic barrels for syrup and are usually glad to get rid of a few.
Jul 31, 2009. 10:25 PMifsconnie says:
Thanks for this suggestion...we actually have a Pepsi bottler a few miles from us!
Jul 16, 2009. 12:41 PMpxbaroni says:
Great system chalked full of ideas for others to use.
Jun 23, 2009. 7:00 AMmystrwizard says:
You could add a small gear motor on it with a timer and have it automatically rotate the barrel once a week.
1-40 of 80next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:Tocsin
