UPDATE: There was some concern that the compost mass would be excessive (someone estimated 300 pounds). Currently, the cylinder is full with composting leaves and kitchen discards and it weighs roughly 35-50 pounds.
Remove these ads by
Signing UpStep 1Materials/Tools List
2-Plywood 2' X 2' (This will be cut into a circle Radius= ???)
Fence wire 3' X 62 (Try to use a fine mesh--mine is ~1/4")
1--2 X 4 X 92-5/8"
1--1 X 4 X 48"
PVC 3/4" X ~35"
~49" Rebar
Nails, staples, glue
TOOLS
Measuring tape
Circular Saw
Sabre Saw
Drill
Hammer
NOTE: I will update this soon with more specific info
So, what I did was to attach a slow RPM motor like a rotisserie motor controlled by a water sprinkler timer which also controlled a drip line that was placed over the tumbler. First the timer starts the motor, then after 5 seconds, the drip line is activated. After about 10 - 15 rotations, the drip line is cut off. The tumbler is continued for another 1/2 hour to make sure everything is mixed. Inside the tumbler I use 1x3 strips to act as "blades" (kind of like what's in your dryer.)
I usually set the timer for 1 activation per 3 days. I've gotten very good results this way.
Turn the drum one way and the compost is mixed and aerated, turn the other and the drum is emptied.
To keep your fingers from getting hurt by the wire, take a long enough plastic tube, cut a long cut and insert the wire mesh in it. It will hold nicely.
Thank you for all your wonderful projects!
old lady.
