3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Composter (Drum Style)
Step 2Stage materials
Note: Your setup may deviate from mine. If so, recalc the dimensions. For the most part this project uses very basic pieces so, for example, if you use a circle that is larger you can re-measure the vertical supports and go from there.
--Cut the plywood into a circle with 10 1/2" radius. (Try not to notice that my circle cut was a little lopsided :)
--Cut 2--2 X 4 to 26"
--Cut 2--1 X 4 to 24"
--Cut PVC to 35"
The wire mesh I used was 3 feet wide and ~62" long.
The crossbeam that goes over the hub should be cut to size based on the size of your drum.
If you are going to use a pan to catch compost that falls thru the wire mesh then increase the height of the 2 X 4. Then adjust the hole in the 2 X 4 so that the drum is higher off the ground, allowing more clearance.
NOTE: I will add more details (e.g. dimensions) soon.
1 comment
Jun 19, 2009. 12:01 PMhv3333 says:
There are simple tricks to mark out perfect circles, like using a nail, some string & a pencil to make a giant compass. An alternative might be to track down one of the plywood drums electrical cable (the larger scale stuff, not standard house wiring stuff) comes on - ready made circles with central holes. I was also wondering about putting the central axis slightly off-centre - if it was moved up very slightly (I'm thinking an inch at most) the drum would naturally settle in the same position the whole time. Another method might be to add a weight to the bottom. Just make sure you position the opening in the right place!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:jdlink
