3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
"Compound" parabolic solar cooker, make a template with technical drawing
Compound parabolic dishes have a super advantage over parabolic dishes. You rarely have to reposition them as the sun moves. So you can leave them unattended for long periods!
There are many possible compound parabolic dish configurations and rather than me try to satisfy everyone, I though it would be better to give you a method to make your own petal templates.
Then you can make a 1 hour, 2 hour 3 hour or 4 hour compound parabolic solar cooker.
Whatever you want is within your grasp! You can easily make petal templates for parabolic dishes with this method too.
For 12 petal templates the error in the method (because you are using flat material to make a surface curved in 3 dimensions) is about 1%. I believe that is acceptable.
If you do not want to read the whole instructable, just read the image notes on the first image.
It should suffice for many people.
Brian
Step 1Compound parabolic concentrators, what are they?
The typical compound parabolic concentrator is a fairly old device, They are shaped like a bicycle light or a tulip flower with a hole at the bottom and as long as the sunlight enters within the acceptance angle it gets reflected all the way down the concentrator and gets trapped there at the bottom. They are made by putting the focus for 2 identical parabolas on the curve of the other one. To do this you have to twist each parabola (which gives you the acceptance angle) and the resultant 2 dimensional shape is spun on its axis to get the flower shape of the compound parabola.
Many times the reflectors for box ovens are based loosely on this type of concentration. They are good because if you face the box cooker the right way it stays collecting sunlight well for a long time.
But I wanted something different. I set out to apply the same principle to parabolic dishes.
Parabolic dishes are great because they can focus a lot of energy but they quickly go out of focus and have to be readjusted. There is virtually nothing out there about applying the same principles to parabolic dishes so I had to start from scratch. My first compound parabolic dish was a great success but not many people were interested in copying my construction method. They prefer a template.
17 comments
Apr 18, 2012. 2:39 PMpdrodrig says:
Hi all,
I read carefully all information posted by gaiatechnician.
I found this webpage that might be interesting for those of you reading this post:
http://solarcooking.org/plans/parabolic-from-flat-sheet.htm
Cheers!
Jul 24, 2011. 1:18 AMstatic says:
I was wondering if you experiment with the compound parabola. Where I live if there is sunshine, on any given day there is enough of it, there's no need to go with extra ordinary measures. A blessing in Winter, a curse in the summer.
Jun 1, 2011. 5:59 PMmscir says:
Great article, thanks!
Please post the patent number for the work you mention by Roland Winston, I'd like to see what he did.
I wrote a freeware program that calculates parabolas of any depth and diameter, you can see or download it here . I'm thinking of writing a calculator to help people make compound parabolic collectors as you've described in this article, they are extremely useful because they don't have to be aimed as parabolic reflectors do, looking at his patent might help me get a few ideas about how to approach it.
Thanks, Mike
Mar 31, 2011. 9:50 PMUser113 says:
Patents themselves are public domain, you can always copy and publish them (the documents themselves), even if they have not expired. The idea behind patents is that by telling others how to make and use the invention, they (the others) will be able to use that knowledge to improve other things. There is an incredible amount of information residing in the U.S. patent database, just waiting to be rediscovered and/or reapplied.
However, if the patents have not expired, you just have to be careful about making, using, offering to sell, selling or importing anything that is covered by the patent's claims. All modern U.S. patents have claims. See 35 U.S.C. 271.
Feb 28, 2011. 11:27 AMnrevelis says:
would like to make one to accept a 9.5 in. pot .Just scaling up approx 49 in petal. can scale up be used or do i have to try to start from scratch.
Mar 2, 2011. 11:08 AMnrevelis says:
I misspoke I intend to take half of template and cut a curve as in the template using 3/8 ply. then duplicate this curve 6 timesto create a half circle. On half circle i will place formica to make a crved half circle,affixing formica as needed with fir strips for backing to hold curve and half circle, repeat for other half making of course a ltittle overlap to connect the two half circles . My computations using your template shows me that this will create shape that is approx 31 1/2 inches in diameter at top and approx 48 inches in height along centerline(focus line ). will line surfaces with mylar. Will also affix a swivel platform for pot and add a side door opening to allow access to food pot . Mount side brackets to allign parabolic to sun and put on a swivel base for any other adjustments to alignment. It seems that this shape is very close to what you would make with wet clay. If you take this concept further you could use these curves to make your cob dome. My real concern is have i done the scaling right. . all i did was measure and expand by 10x. Surly do arrpeciate ypu taking the time to respond. I am a almost total novice . Have built large solar oven that gets to 400 on a nice day . This should have about 800 sq in surface and be suitable for cooking . Question "is this doable?
Mar 8, 2011. 3:54 PMnrevelis says:
took your advice googled winston cone came up with a drawing of cone had it blown up 10x and am in process of making one not being a techie i would not even try to understand the math but if a guy like winston says it works i will take his word for it. if i am able to get it done right i will let you all know how i did it. nick
Feb 15, 2011. 1:53 AMKwena Moxadi says:
Hello, I'm a first year student for engineering and we've been given a project to design and construct a solar cooker. I'm finding it hard to follow these steps because I'm not familiar with all the technical steps. please summarise these steps in simpler language for me to follow, starting even with potential material to be used. I'd appreciate it so much if you do. pictures not necessary.
May 14, 2010. 11:36 AMdanno says:
Nothing in your instructions showed how you made the base for the reflective strips..... There's a huge leap from drawings to finished bowl to glue reflective strips to
Jan 15, 2009. 2:59 PMrobbtoberfest says:
Is the energy less intense on the focus than a standard parabolic reflector because your sacrificing direct aim at the sun?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
74
Author:gaiatechnician
I am a stone mason. My hobby is making new solar cooking and gardening stuff. I have used solar heat to cook soil for a couple of years. In mother earth news in January, i read that their compost expe...
more »
