3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Kyoto trough solar cooker mimics a parabolic dish without a thousand cuts!
  • last photo ←
The kyoto trough uses troughs with their curvature at right angles to each other to mimic a parabolic dish. Bending and cutting sheet material to make the trough requires as little as 2 cuts of the sheet material.. On the other hand
Cutting sheet material to make a parabolic dish is a massive undertaking!
I have made a first prototype and it works.
It is"tweaked" to provide 2 hours of cooking time at pretty much full power. So you can set it and leave it. A parabolic dish on the other hand needs to be adjusted every half hour.
The trough arises from a solar software project I did.
I have uploaded the most recent scene file here thirdcombined troughblabla.aoi If you download it, it might change the file extension to .temp. Just change it back to .aoi and it will work just fine when you open it in art of illusion
The file just happens to contain a parabolic dish, winston curve dish, and various others too. And all in 11kbytes!
Art of illusion software certainly helped me come up with this design.
http://www.youtube.com/watch?v=qXVfGFQpYD8 shows my first prototype Kyoto trough.
Brian
Step 1Concentrating sunlight with 2 troughs (why it works)
You can concentrate sunlight to a point of light as shown by a Swedish guy over 30 years ago!
Here is one of his videos of how it works.
http://www.youtube.com/watch?v=FYzgYI9_h6s
I want to solar cook so I do not want a point of light. Instead I want the light to focus on the place where my cooking pot will be for 2 hours. How can I do it? First thing is to make a compound trough. This is easy. You just make a parabolic trough and twist its sides inwards. If you twist both sides inwards by 15 degrees each, you have a 30 degree "acceptance angle" . If you allign it with the suns path, and let the sun shine over it, for 2 hours, all the light from both sides will fall at or below the focus of the dish.
So there is some concentration!
So put your pot here. But the trough is wider than your pot! so the next stage is to concentrate that light a bit more. This is where the wings come in. They are parabolas too and they have a focus on the front of the pot and a focus on the back of the pot.
As long of their angle of rotation is at right angles to the angle of rotation to the first trough, they will not affect that rule "at or below the focal line" when the light arrives under it but it will concentrate the light towards the center of the trough! (I give these parabolas a little twist inwards too to do the at or below thing and spread the light over the pot a bit more).
11 comments
Mar 7, 2012. 12:18 AMbovineboy says:
Are you sure these aren't pictures of the UFO that crashed at Roswell? :)
Jul 27, 2009. 7:58 AMmacrumpton says:
Here is a related idea that I came up with this last week when I was trying to come up with an easy way to make a parabolic collector. I think the folded up sections might perform similarly to the secondary reflector in this instructible. The best part of my design is that it is made of a single flat sheet with no cuts and you can change the focal length by changing how much you bend the end flaps towards the center. I have not tested it at all, as it has been cloudy all day, but it seems to work concentrating a light bulbs light pretty well (it also makes a pretty good cheap reflector for DIY floodlights). To make cardboard take the curve better you can paint one side of it with some latex paint. When the paint dries it will shrink and the cardboard will curve towards that side.
Apr 17, 2011. 11:33 AMGreenMeUpScotty says:
I think you are onto something with your design. I am also working on a CST that the average homeowner can afford. What is the material you are holding and where do I get it? scottscontracting@gmail.com.
I will be posting information on my design and resources at: http://stlouisrenewableenergy.blogspot.com
Keep up the Green and Sustainable Designs. The way the Politicians in office are going it will be up to Jane and Joe Citizens to make this a pollution free world. And once more people are creating True Green Energy that does not have harmful residues such as nuclear radio active waste and harmful exhausts from Oil, Coal, and Natural Gas.
We will remove the Grip that the Fossil Fuel Companies have on our Elected Leaders from their campaign donations- find out for yourself and http://opensecrets.org and you too will have an "a-hah" moment on why your elected leaders are voting the way they are.
My best to all, Green Me UP-Scotty
Apr 18, 2011. 3:29 PMmacrumpton says:
I just used some spray glue to laminate some aluminum foil onto some card stock, but for a larger one I would probably use some coroplast (fluted Polypropylene) which is like plastic corrugated cardboard.
Dec 4, 2009. 10:34 PMIdonet says:
And here - you don't anything to say?  ;-)
Jul 28, 2009. 7:43 AMmacrumpton says:
I think this idea has a lot of potential, especially if it can be incorporated into an exterior wall or roof. It seems like having the secondary reflector movable could make up for the main reflector being stationary. Can I suggest that yyou check out the 3d modeling tool sketchup? It is very easy to learn and there is a free version that is quite capable and it has a huge helpful userbase as well as being able to export into many helpful formats.
May 19, 2009. 12:09 PMlemonie says:
Good to see a build of this - have you had enough sun to collect some data w/ref temp / power etc?
L
(Need text under step 5 Why do 2 troughs work to concentrate light?)
Apr 26, 2009. 2:08 PMSolReka says:
Compound parabolic cookers certainly are a lot easier to build than commercial accurate parabolic cookers. The advantage of CPCs - Compound Parabolic Cookers, is that you don't need to turn the cooker to point towards the sun as often as you would for a highly accurate parabola.
I love the simplicity of your design, it's a great way for people to learn about the wonderful world of solar cooking.
I offer similar cooker kits for under $20. There are ebooks, parabolic templates, building materials, and solar cooker kits available.
http://www.solreka.com/solar-cookers.html
Regards
Sol
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
74
Author:gaiatechnician
I am a stone mason. My hobby is making new solar cooking and gardening stuff. I have used solar heat to cook soil for a couple of years. In mother earth news in January, i read that their compost expe...
more »
