Comprehensive Xbox 360 RROD guide
 by ludionis
Step 3: So, how to fix it?
If your box is malfunctioning due to simple overheating or poor heat transfer between the processor and heat sink, following instructions such as the X-clamp fix, or the instructable at http://www.instructables.com/id/Fix-the-Red-Ring-of-Deathwithout-towels/ would be a good first place to start. As mentioned in that instructable, if your Xbox is covered under warranty, why on earth are you trying to fix it yourself? MICROSOFT WILL FIX IT FOR FREE IF SEAL IS INTACT AND REGISTERED TO YOU!!! Do NOT drill the case unless you want to buy a new metal shield (like I had to) to ship it off...more details in step 9. The steps in that and this instructable should only be undertaken on a machine that has no seal, is registered to someone else, and there is absolutely no way you can get Microsoft to do it for you under their warranty. If this doesn't fix it, we've got a bigger problem...
whyexactly says: Dec 9, 2010. 9:11 PM
its worth noting that if you have a sealed console that is reg'd to someone else, you can call up support and ask them to transfer the console to you, just give them the serial number (don't mention that it's broken already though). They should swap it over for you.
ludionis (author) in reply to whyexactlyDec 10, 2010. 5:04 AM
I did that one time. Not sure if things have changed, but I had to provide the original persons information. I had bought the unit off a kid on craigslist, and her was willing to give me his live account id, name, etc.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
