Step 26Time to place your components
You can screw directly into the fiberglass, or if you need to build a larger surface area, you can use dental acrylic to build yourself a better surface mount wherever you need it.
It's important to remember when installing your components, that you will likely need to access them in the future. Making them as easily removable as possible will definitely help if you run into any problems down the line.
I installed a bar across the top for the DVD drive to rest on, with enough room for the cords and the LED wires to wrap around the far side of it. I then mounted the hard drive to the side of the beaver with the aluminum sheeting and some screws.
Attach the power button internally. The switch I used just required two screws, which went into the fiberglass just fine. The modified straw filled with JB weld then stuck out his middle. I then attached a standard red power button on the other side.
Add Comment
