Computer Assembly
Published
Introduction: Computer Assembly
Page 1 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Introduction
Page 2 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Procuring Parts
Page 3 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Gather Tools and Supplies
Page 4 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Open the Case
Page 5 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Prepare the Case for Assembly
Page 6 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Ground Yourself
Page 7 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Install Motherboard
Page 8 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Install Hard Drive
Page 9 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Install Optical Drive
Page 10 . . . . . . . . . . . . . . . . . . . . . . . . . . . . Install the CPU
Page 11 . . . . . . . . . . . . . . . . . . . . . . . . . . . . Install RAM
Page 12 . . . . . . . . . . . . . . . . . . . . . . . . . . . . Install the CPU Fan
Page 13 . . . . . . . . . . . . . . . . . . . . . . . . . . . . Install Case Fan
Page 14 . . . . . . . . . . . . . . . . . . . . . . . . . . . . Install Power Supply
Page 15 . . . . . . . . . . . . . . . . . . . . . . . . . . . . Connect Cables
Page 16 . . . . . . . . . . . . . . . . . . . . . . . . . . . . Wrap-up
Step 1: Introduction
This set of instructions will help you assemble a PC made for your needs of running certain software's. This guide will show how to build a PC, the tools required to build a PC, as well as a in depth description of the parts required.
Step 2: Getting Parts
In order to build a PC, you must have certain parts in order to have your PC work. If any of the parts were missing, the PC would not run as it works just like the human body, where every part has a playing role in order to work. A list of the parts required are listed down below.
- PC tower
- Motherboard
- CPU (processor)
- Hard Drive
- RAM (random access memory)
- Power Supply
- Case Fan
Step 3: Gathering Tools/ Supplies
Once you have your parts gathered, you will then need tools and supplies to install the parts. A list of tools and supplies is provided below.
-Screwdriver (for slotted and Phillips head screws)
-Needle-nosed pliers
-Utility knife -Small flashlight
-Adjustable wrench
-Small container to hold screws
Step 4: Preparing Case for Assembly
The case is the part that stores all of the parts to keep the users work area organized. The case is also a template for the user when they are building their PC so they know where every part goes. The first step of building a PC is to slide off the side PC cover. Once it's off, remove any packaging outside and inside the Case. Once the packaging is off, you are ready to start the next step.
Step 5: Install Motherboard
Now you are ready to install the motherboard. The motherboard is essentially the brain of the computer. The motherboard commands all the other parts to do their role in order for the PC to work. Grab the motherboard and place it into the place the case says to install it. Next grab the screws and put them in one by one and screw them in. Be careful when putting in screws since they are very small and easy to lose. Also make sure you have the correct screw drive to ensure that you don't ruin the screw head by accident. Once the motherboard is securely in place you are ready to move onto the next step.
Step 6: Install Hard Drive
The hard drive is a device that stores all of a user's data. To install the hard drive, all you have to do is slide the hard drive into place where you can see the screw holes and then screw the screws in.
Step 7: Install the CPU
The CPU is essentially the brain of the computer. To install the CPU, find the corner marking that designates pin 1 of the CPU, once you have found that, Lift the small metal rod and place the CPU in designated area.
Step 8: Install RAM
The RAM is a temporary location for memory that the processor works from. When installing the RAM sticks, line them up perfectly and then push down firmly on them until the are in place.
Step 9: Install Case Fan
The case fan's purpose is to keep the PC from overheating mainly because overheating can cause it damage parts inside of the PC. When installing the fan, Align the mounting holes by holding the fan to the mounting pad on the inside of the case, then use the screws to secure it in place.
Step 10: Install Power Supply
The power supply converts currents into low power voltage which is then sent out to all PC parts to keep them running. To install the power supply, Align the mounting holes in the case and power supply, then insert screws and tighten until it is firm in place.
Step 11: Connect the Cables
In order for the PC to work, every device that has been installed needs power. Each Part is connected to the power supply which gives each part power so that they can run when the PC is on. The parts are given power through the cables. If you are still confused about the cables, there are many videos that can help you out.
Step 12: Wrap Up and Test
Now that all of your parts are put together and are connected to wires, it is time to test the PC out. Slide the case panel back on and plug your PC into a wall and plug the PC into a monitor as well. If it does not work, you might have to go back and look at the steps again to make sure you aren't missing anything but if it works, the congratulations, you have just successfully built a PC.
    • Clocks Contest
      Clocks Contest
    • Planter Challenge
      Planter Challenge
    • Casting Contest
      Casting Contest
    Hello there!
    We're glad you want to share something with the Instructables community!
    And we’re here to help you out.
    In order to be published live on the site, Instructables must consist of the following things:
    - Multiple steps showing how you made your project
    - Written instructions in each step
    - Your own original images
    Beyond making your Instructable simply publishable, this guide (https://www.instructables.com/id/How-to-Create-a-Feature-Worthy-Instructable/) explains what is required to have your Instructables featured by our site editors. It’s very helpful, and definitely worth checking out.
    We would love to review your project again after you have made the necessary edits, and we will publish your project if it is eligible.
    If you have any questions, please feel free to ask right here or send us an email at service@instructables.com.
    Best,
    Instructables Community Manager
