Step 1: Tools of the trade
Gather your supplies, I included but might not use each time:
Pliers
Solder
Circuit Board (obsolete/dead)
Tape
Soldering Iron
Super Glue
Paints
Paintbrush
Toothpicks
Knife
Nail Clippers
Step 2: Stripping
A quick and dirty way to get your parts is to heat up one side of the board where the part is and pull on the other with pliers or fingers. Rocking it back and forth as you do will work it out slowly.
WARNING WATCH THOSE FINGERS SO YOU DON"T GET BURNT!
Please be careful as you could burn yourself on this step. Always prep your iron before use, cleaned and tinned for maximum efficiency.
Gather as many parts as you can, off any thing you can find.
VCRs, computers, clocks, printers, stereo equipment etc. are great sources for parts
I keep mine in a compartmentalized box sorted by type, color, shape and/or size.
Step 9: Soldering Take 4
Now to finish up the soldering, place the head in position and zap it with the iron. If did the head the other way you can add small diodes or resistors here for antenna.
Step 10: Eyeballs
Bugs don't have eyeballs but this isn't your typical bug.
Start with a base color, I used off white here, and make a big spot with a toothpick.
Let dry a bit then use a darker color (this time black) to make the pupil.
A steady hand is recommended for this step, it helps to rest your hands against each other to do fine work like this.
Colors are up to you and can be very wild if you want.
(shown here not attached to body for clarity)
Step 11: Glossy
A final coat of gloss will give the eyes a bit of depth and protect the paint from chipping.
1-40 of 131Next »
KionK says: Feb 11, 2013. 3:29 PM
Ii is a good idea....
aliyevzaur1989 says: Jun 17, 2010. 10:05 AM
What a waste of electronic components
ssshag in reply to aliyevzaur1989Sep 14, 2012. 11:25 PM
Define "waste".
aliyevzaur1989 in reply to ssshagFeb 1, 2013. 5:21 AM
Someone can use these parts to build some useful circuits.
hippyland2 in reply to aliyevzaur1989Jun 18, 2010. 11:18 AM
your right. yuor suposed to just recycle the computer not waste them. also how does this help save the enviorment?
ssshag in reply to hippyland2Sep 14, 2012. 11:31 PM
"your right"
Yes, it IS his right.
"yuor suposed … the computer not waste them" ; "enviorment"
Uh, this is a joke, correct??
nnygamer (author) in reply to aliyevzaur1989Jun 17, 2010. 1:25 PM
All the others disagree beside the components were all obsolete or broken it's better to reuse the parts then throw them away.
master key in reply to nnygamerFeb 17, 2013. 1:26 PM
some people find uses for working obsolete computes and computer parts
vadipp in reply to nnygamerFeb 3, 2012. 11:04 AM
And bring joy into this world, too :)
Myself says: Aug 20, 2007. 10:03 PM
I'm really surprised that you managed to find tantalum caps with such longs leads. Aren't they usually bent and trimmed pretty short? I'm guessing those were diagonal across DIP sockets, which are getting rare. Also, without getting too negative, can I nudge you on the "save the environment" line? I understand that these components don't go immediately into a landfill, but they also don't prevent anything new from being made, and they will probably end up in a landfill eventually. I see zero environmental impact from this, neither positive nor negative. I'm curious to hear your take on it.
ssshag in reply to MyselfSep 15, 2012. 12:43 AM
This IS in the realm of "save the environment" -- it IS recycling, and just as valid as any other recycling. THIS is something new getting made--art/craft. Anyway, eventually many or most of those other things being made from "traditional" recycling will end up where? They'll end up at, sooner, if not later (at the end of their recycling life), the landfill.
nnygamer (author) in reply to MyselfSep 8, 2007. 11:59 AM
I know that it won't do much for the environment at first, but I hope that the bugs made will be around for a while and by the time they do end up being discarded the policies on recycling them will be much more advanced then now. As for the tantalum caps, well almost all my parts came from boards my cousin gave me that would have otherwise be buried in a landfill now. I think those came from an old Ethernet router.
build52 says: Jun 17, 2012. 6:18 PM
great job! 5 star!!!
Husham Samir says: Jun 17, 2012. 3:35 AM
Awesome!!!!
DELETED_trevyboy says: Oct 17, 2010. 11:10 AM
(removed by author or community request)
nnygamer (author) in reply to DELETED_trevyboyOct 29, 2010. 1:52 PM
There are all kinds of places to get the components. Old radios, boom boxes, TV's (be careful with them), some telephones (not cell phones), VCRs, DVD players, clock radios.
I just happened to have a bunch of old obsolete computer parts to work with and it turned out great to call them Computer Bugs.
pastanaut in reply to nnygamerOct 21, 2011. 8:38 AM
If you don't know what a capacitor looks like, don't take apart old TVs! The capacitor can discharge and kill you if you don't know what you're doing.
OrIsIt in reply to pastanautJun 5, 2012. 10:54 AM
You sure? Even if you take it out of power and leave it for a couple of days. I heard the engergy radiates after a couple of days
nnygamer (author) in reply to OrIsItJun 6, 2012. 7:20 AM
The energy can stay in them for weeks, I know I took apart a monitor once that hadn't been used in a month and got zapped. I sat down for about 10 minutes and was just in a daze not being able to think straight. I was very lucky.
vadipp in reply to pastanautFeb 3, 2012. 11:00 AM
Or, just LONG-circuit (using a several Ohm resistor) all components you see before touching them :)
redsunmtm in reply to nnygamerSep 13, 2011. 4:21 PM
not agree with you when you say "not cell phones", just take a look on my sculptures on the link i gave up here and you'll see a lot of cel phone components solded together, it is just question of pacience and good tools to solder them a sure a good technique an many imagination ! ;P
nnygamer (author) in reply to redsunmtmSep 16, 2011. 4:34 PM
Most cell phones have SMD that are hard to work with if you have fat fingers like me. I do use them as detailing on models though.
for those who don't know SMD= surface mount device
lsutigertuff says: Jan 25, 2012. 2:14 PM
Great Idea!!
urielh says: Dec 8, 2011. 12:54 PM
it's realy work?
FraKtuL says: Apr 28, 2011. 2:02 PM
Awesome! I think I've finally found a purpose for my collection of 386 motherboards and ISA stuff that I can't seem to GIVE away on Craigslist. :)
BTW: The "free" section on Craigslist is a great source to find broken electronics that some people just don't want to throw away.
redsunmtm in reply to FraKtuLSep 13, 2011. 6:00 PM
you should take a look here: http://www.youtube.com/user/redsunmtm#p/a/u/0/B-x8gjJVxE4 have a nice view and get good ideas !
redsunmtm says: Sep 13, 2011. 4:14 PM
you should look this page i do those things for more than 15 year now !
http://eclipse-online.info/ go to sultures section and then: roll over to find SCULPTURES ELECTRONIQUES just after wood ones
thevansleaving says: Nov 27, 2010. 10:08 PM
This is a great idea! Does anyone know how much these might weigh? These would make some really cute earrings to give away as presents if they don't weigh to much :D Or even a cute necklace!
nnygamer (author) in reply to thevansleavingDec 4, 2010. 9:36 AM
They don't weigh much at all. I've seen regular earrings that probably weighed more.
Just solder a pin to the body, cut off and hook it to a craft earring hanger. I'd make sure the feet were smooth with a small blob of solder to prevent picking and catching.
JOBGG in reply to nnygamerMay 2, 2011. 2:55 PM
And you might want to use lead free solder and ROHS compliant components for anything you ever think about sticking into a hole anywhere in your body...just to be safe, lead poisoning is no fun. But yeah, these are pretty light, unless you just have to hang a 1F 200V Capacitor monsterbug from your face.
nnygamer (author) in reply to JOBGGSep 2, 2011. 3:20 PM
Also a nice coat of clear nail polish over the whole thing will help seal it.
CielMarcheur says: Jul 3, 2011. 2:01 PM
This is brilliant ! Congratulations. I love your creations.
I'll try to do some.
thomathome says: Jun 23, 2011. 7:06 AM
love this idea been making them for ages. I made a bunch of winged ants and solderd them to some old sim cards : ) Sim-bee-ants! anyone?
acosicris says: Jun 14, 2011. 8:48 AM
I hate bugs! But those seems to be harmless. LOL.
Nice ible!!!
vishalapr says: May 30, 2011. 9:27 AM
I like the ible but I would personally use those parts, well done on this ible!!!
SysGhost says: May 10, 2011. 12:57 AM
Oh dear. If I ever see those buggers crawling out from under my computer, it's a sign that I need to clean up my program code from bugs.
apaterson1 says: Apr 22, 2011. 10:33 AM
would the resistors still work if i wanted to recycle them into another project?
nnygamer (author) in reply to apaterson1Apr 22, 2011. 11:33 AM
I don't see why not. As long as you don't overheat any of the components they should be good to reuse.
nbagf says: Apr 14, 2011. 7:22 PM
woudn't it be random if these were able to be used in projects
rcosmo says: Mar 27, 2011. 7:54 PM
Soo cute! im so gonna make it tomorrow right after i wake up xD
1-40 of 131Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
