Materials:
1) Large (2 inch) Binder Clips - under $4 for a box of 12
2) 3/4" Wood Screws - under $1 for a box
3) Washers - under $1 for a box
(Optional)
Velcro Straps
Tools:
Screw Driver or Power Screw Driver
Remove these ads by
Signing UpStep 1Unplug, Untangle, & Gather the Supplies
Gather your supplies. I am using 3/4 inch length screws because my desk is 1 inch thick. It is important that you take the time to measure your desktop. Pick a screw length that is at least 1/4 inch shorter than the thickness of your desktop. A sure fire way to ruin your day is to finish the project and find that you now have 8 screws sticking up through your desktop.
A thousand time THANK YOU!
I cut it into 6"long pieces, and ran a thin wire down the center. I then used a short wood screw at each end and screwed the wire to the under side of the desk.
The I cut slits almost through the tube to grip the wire and allow me to pull put what I needed. Pull out too much? Stuff it back into the slit Cheap and fast..
Also should never ever place any form of electronics on top of your subwoofer especially anything containing a hard drive the huge magnet thats in subwoofers fries nearly any hard drive it comes in touch with
A good safety measure is at least a good 2 feet of distance between sub and whatever it is your using,in this case xbox,depending on size of sub though distance will vary.
Thanks for the feedback!
Charlie Flowers
DailyHack.net
twitter.com/charlie
