Computer Fan Cover Shelf Unit
 by TitanTechRobotics
Featured
This is an easy to make shelf that uses a few fan covers, some standoffs, and a few nuts and bolts.  It can be used to hold various things, and in the horizontal position it can be used to hold CD cases.
Materials:
4) 120cm computer fan covers (I got mine from all electronics) -- about $1.20 each
9) 6in standoffs(other lengths will work)(I got mine from electronic goldmine) -- $.49 each
3) screws that fit into the standoff(10-32 in this case)(I got them from a local hardware store) -- around $1
3) nuts that fit onto the standoff(10-32 in this case)(I got them from a local hardware store) -- around $1
Total: about $10 (about 6.5 GBP)
Step 1: Base of the Shelf
1) Start with one fan cover, make sure that the "prongs" that stick out of it are higher that the main part of then cover.
2) Put the screw through the "prong" and into the standoff
3) Tighten the screw
4) Repeat 2 and 3 until you have 3 standoffs attached
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
