In my house we have a gas fireplace, because we do not like running the heater and it saves money and the environment.
What i have noticed was the gas fireplace doesn't spread the heat around the room.
So i made a fan system out of a couple dead computer fans.
Remove these ads by
Signing UpStep 1What i Did
I took a three computer fans and hooked them up to a 12v converter, then i set them up so they would
push the hot air out of our gas log fireplace saving us money, and reducing my carbon foot print.
The problem with those fires is the pretty-flames, if you modified it to heat some kind of mantle and have an exhaust to room heat exchanger, like ugly gas fires (pic), you might feel it a bit more.
L
L
L
L
its a puzzler that they don't melt!
the carbon monoxide sensor in your fireplace is probably to detect an excess of CO in the firebox itself (i.e. the area immediately around the fireplace). which is great if your flue or exhaust system breaks or clogs up and CO starts backing up into the fireplace...HOWEVER, you're forcing the air from the firebox out into the room, by the time the CO levels in your room get high enough to trip the sensors IN the firebox, you're probably at a toxic level in the rest of the room (or god forbid the rest of the house). you should put a CO sensor (they make CO/Smoke/CO2 combo detectors) somewhere in the center of the room
All fires like this produce CO so the detectors are pretty much tolerant of a certain amount - as far as they are concerned the fumes are being vented up a flue so a certain amount is fine. They only trigger when the amount of CO goes up a LOT signifying a blocked flue.
Fireman115 - you are effectively diverting some of the gases which would normally pass up the flue into the room, the CO detector is not going to spot this and will assume all is OK. Since you are taking some of the gases away from it my guess is you will actually lower the effectiveness of the detector in the event of an actual blockage.
Sorry to seem down on your idea but seriously you could, in theory, kill yourself.
As for the melting of the fans, heat rises so the fans don't melt but it still allows for the hot air to be pushed out.
As for the carbon monoxide i am not sure...
