3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Computer Hacking For Noobs
How to hack you're computer's account using command pronpt.This stuff is really interesting and EVIL!!!
**Edit**
**Announcement**
Ok, due to popular demand, Imgo add actual screenshots, use spellcheck and try to add helpful tips. So all you nagging *** get off my back!!!!
In this instructable, youu'l learn how to unblock command prompt, crete and change accounts, and change other people's passwords without them knowing!!!
You can even give youreself administrative privaleges...
Step 1How to get CMD Prompt working
There are two options here:
1.If you have access to the run feature (in the start menu or press windows button-r), you should be able to access command prompt by typing CMD into the dialouge box (pictured below). You are lucky and you can skip the next step. cya on the next step, bye!
2. If you are unlucky, and you cannot find the run feature in the start meny, you're account is probably not blessed with administrative privalages. But we can fix that...
Open notepad (which is in the start menu under accessories)
Then type in "Command.com" (whithout the quotation marks). After that, type on a new line (by pressing the enter key once) "pause" (once again with out the quotation marks).
Got that?
Now for the tricky part. Click the save button under the file drop-down tab in the top left hand corner of the window. a menu should come up that allows you to browse files.Name the file as follows:
CMD.Bat.
(The .bat means that it is a batch file for those noobs that are curious. Batch files are the language of command prompt.)
Save the file in a convieneant and easy to access place (I used my desktop)You should now have a fully functional showtcut to access the Command Prompt Interface. If this doesnt work, leave me a comment or message and i'l get back to you as soon as possible.
144 comments
1-40 of 144next »
Apr 28, 2012. 3:09 PMTitanium Rainbow says:
So all you have to do to get in is CMD, didn't know that
Apr 2, 2012. 12:27 AMjoeioe says:
Do you mean Command Prompt on Step 2 or do you really mean Notepad?
Mar 10, 2012. 12:59 AMDashadower says:
mine said acces denied
Mar 9, 2012. 11:02 AMAllexio says:
Please tell me if I should write what is in brackets...
Feb 24, 2012. 7:14 PMlstar789 says:
everytime i try this it says invalid switch - / please help
May 4, 2011. 12:50 PMzuesfrost says:
it did do some crap but didnt say anything was complete
Apr 23, 2011. 6:59 PMtbowden says:
rename halo.exe or haloce.exe to iexplore.exe and it should work. i did the same thing then realized they only ban the name of the game.
Feb 3, 2010. 12:07 AMtramaeivoi says:
It's clear that no one can make accounts from a limited account !
I tried this but it says :
System error 5 has occurred.
Access is denied.
Mar 26, 2010. 11:12 PMXmas50 says:
Do this.
1.Type in cd /
2.Type in cd WINDOWS/system32
This will have you running as  a windows god more or less.
Feb 11, 2010. 3:33 AMmessmaker says:
Yea,
my administraitors have banned us from saving files as batch.
theyve also blocked Run...
and Hot Keys dont work.
Mar 3, 2010. 1:23 PMaspangmac says:
 try running the file from a flash drive, USB drive, thumb drive ,portable harddrive.  first create the file on another computer then plug in to the desired computer and run.
p.s.  i am not sure that this will work but i think it will
good luck
Mar 19, 2010. 4:37 AMmessmaker says:
Thanks =D
I've found a way around the website blocks, and its not a proxy =]
Dec 14, 2008. 6:00 PMdude111115 says:
oh, and you dont need to go through all that crap to get the cmd open. even limited users can do it. hit Windowkey+R and the "Run" box pops right open.
Mar 3, 2010. 1:37 PMaspangmac says:
 some schools have blocked key shortcuts such as winkey+R
Jan 19, 2009. 7:54 PMThe_Black_Hole says:
there is and easier way... just go to the command prompt and type for example:
administrator *
and it will ask you to type and re-type a new password.
Mar 3, 2010. 1:25 PMaspangmac says:
 Yeah Right
Jan 12, 2010. 10:22 PMsykot1c says:
Coo
Oct 31, 2009. 9:00 PMsnypemasta says:
Mine does'nt work, at my school they have a block on you saving files as .cmd or .bat plz help?
Apr 28, 2009. 8:14 PMitvalsad says:
my command prompt did not work as per your instructions - so please help me - my e mail is itvalsad@hotmail.com
Oct 12, 2009. 12:09 PMsharlston says:
use this code:
@echo off
color 0a
:Input
title @ %CD%
echo.
set/p "command= +++> "
%command%
goto Input
and save as a batch
Jul 8, 2011. 2:06 PMgrampafish says:
The pc I want to hack is a school computer
Dec 4, 2009. 6:34 AMgrampafish says:
how can i hack into novel and get admin rights
May 29, 2009. 5:17 PMhg341 says:
I hate novel and so dose my tech teacher
Jul 2, 2009. 5:48 PMdeathzone says:
everyone who has a brain and likes to you know be able to actually use a computer that has more capabilities than a typewritter hates novel.
Jul 2, 2009. 7:55 PMhg341 says:
yea thats ture our paided techys love it they get to be lazy
Jun 20, 2009. 6:57 PMteslafan100 says:
SO FUNNY
Jun 12, 2009. 3:19 PMcloot100 says:
and good idea
lol your hilarious!
Aug 18, 2008. 4:53 PMQwertyuioLP says:
Cmd at school is block when I turn it on it pops up and says command prompt is blocked access denied press any key to continue. can u fix it??
Mar 23, 2009. 1:55 PMN1CK4ND0 says:
Open a new text document, and type: command.com Then, save as, CMD.bat Open it, and you have command prompt working.
Jun 4, 2009. 5:47 AManiman1 says:
dont you know that all you have to do is type start? simple
Mar 7, 2009. 2:58 PMgonturan says:
Try this instructable.
Mar 11, 2009. 3:42 AMQwertyuioLP says:
I have tried it and it does not work. Is there a registry hack to get it working?
Sep 7, 2008. 5:47 AMStanic says:
in notepad write command.com and save it as a .bat file
The problem is that in some schools you can't open batch files..
I hope this helps... =)
Mar 23, 2009. 11:16 PMQwertyuioLP says:
Thanks but my new school is one of the school where you can't run batch files!! So was my old school!
Mar 23, 2009. 1:56 PMN1CK4ND0 says:
Oh sorry, just taught the same technique, didn't see your comment.
May 29, 2009. 5:19 PMhg341 says:
Sep 4, 2008. 2:59 AMQwertyuioLP says:
any one is there a way to un-block cmd from admin???
1-40 of 144next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:neardood(My Youtube)
I like electronics, blowing stuff up, fun and reading. If you have anything cool, please email me!
