Materials you will need:
1)plexiglass
2)small 1/2 to 3/4 inch screws
3)drill with bits
4)a way to cut your case material (in my case a dremel cut right through the metal)
5)hand screw driver
6)masking tape
7)File
8) 1/4 inch tubing
8)anything you think would look cool on your computer (I used some neon orange wire sleeve, blue cold cathode light, light up ATA cable, and SATA led cable)
There is so many computer mod sites I used http://www.xpcgear.com/casemodding.html
Remove these ads by
Signing UpStep 1The Window
The first thing you will want to do is decide if you want to have just a hole, a hole with tubing around the edges, or a hole with tubing and plexi-glass (a true window).
Take off your door panel and look at your computer for any parts that will prevent your door from fully closeing. In my case it happened to be a support beam for my power supply and the lip at the rear of my case. These parts caused my first attempt to fail. So measure and measure again.
Add 1 1/2 inch of clearence to your measurements to allow for the extra plexi-glass. Then mark your window on your case useing some masking tape and start cutting.
But you suck at cable management. but still far much cheaper than other tible
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119194 thats the one i use and if i take the sides off my temps go up 20c
