Step 2The Window cont....
Take your plexi-glass and cut it to fit you window with about 1 1/2 inches extra on each side. carfuly drill a hole in your door that is slightly bigger than your screw, now center you plexi-glass over you window, you should be able to see the hole in the door that you just drilled. Carfuly (don't push to hard on the plexi-glass) drill a hole that lines up with the hole in the door (make sure the hole is smaller than your screw). repeat this untill your plexi-glass is secure. TA-DA you have a window.
If my directions were a little unclear you can check these two sites, I found they helped my a lot http://www.instructables.com/id/E0TPGA73GTEP287FTT/
http://www.amd.com/us-en/Processors/ComputingSolutions/0,,30_288_13265_13295%5E13330,00.html
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119194 thats the one i use and if i take the sides off my temps go up 20c
