Step 3Adding Wire Sleeves
I first unpluged everything from the mother board except the CPU fan (that is assuming you can put everything back together). I only had 4 feet so I was limited to my choice of cables, I picked my 4 pin connector, LED/speaker wires, and another unknown cable (I just know where its goes not what it does). Anyway you just slide one end of the sleeve over your cable untill you have reached the desired legnth (mine was as far as it could go) then cut the sleeve off at the end of your cable. Add cable ties to prevent the sleeve from fraying and you're done, pretty simple.
4
comments
Add Comment
Add Comment
