3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Computer Mod
Step 5Cold Cathode Lights!!!!
This is pretty much the same as the previous step but oh well ill do it anyway.
First I recommend the small 4 inch lights because they go almost anywhere in you case, if you get 4 inch ones I recommend getting two (that means two packages of two lights).
Get out the switch (that should fit in a PCI slot) and screw that down. Then connect the switch to the box, Then hide the box and tape it down using the tape they provide (but it has to be close to where your lights will be placed). Mount the lights using the tape/velcro that they provide and plug them into the box. Now connect the switch to the 4 pin power connector and you're done.
1 comment
Nov 28, 2011. 12:08 PMshtihl says:
Cold Cathode lights do have a limited life span but the control box and switch are basically the same so when it comes time to replace the light bars, you dont have to completely uninstall them. kudos for thinking of the 4 inch bars. make sure you completely clean the surface you are going to mount to as this will cause the tape to come undone
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:easycom89
YEAYY!
