In my case, I decided to replace the fan because my cheap power supply's fan started making enough noise to drive me to distraction...
WARNINGS
- Power supplies have dangerous voltages inside, even when completely disconnected. Capacitors on the line side usually retain their full charge even when unplugged, and can inflict a painful or even lethal shock. Please proceed only if you know what you are doing.
- Disassembling the power supply will void its warranty.
- Opening your PC may void its warranty, though I haven't come across such a computer so far. Also, fiddling with the insides may damage other components, so go ahead only if you are sure of yourself.
- 2011-05-02 : Corrected explanation of fan dimensions. Thanks to KanyonKris for the correction (see comment at bottom)
Remove these ads by
Signing UpStep 1Before you start
For your safety:
Before opening the power supply, try to discharge the capacitors inside as much as possible. I did this by switching on the PC and unplugging the power cord. Of course, there is no guarantee that this will completely discharge the capacitors.
Another method is to use a 1 megaohm resistor to short the capacitors. The capacitors are the large ones shown in step 6.
I find that if the fan is really annoyingly noisy, pulling off the label and removing the rubber plug, exposing the bearing (sleeve or ball), then applying a few drops of 3-in-1 oil and letting it settle in virtually silences them, so you get more use out of them and more time to go buy a new fan... :)
And yes, do be careful of them capacitors, I have been shocked a couple of times by them, and it hurts, majorly!!! It's like someone stabbing a hot screwdriver into your skin and muscles, it's not something that you'd want to happen, well, not unless you're a weirdo... :S
For example: a 80mm fan is 80mm across. The distance between screw holes is 71.5mm.
Also make sure the width (W in image below) of the replacement fan will fit in the power supply. The easiest way to do this is to buy a replacement that has the same width as the old fan.
Still, I think you are right, I'll update the instructable as soon as I find a decent reference to link to.
I too was surprised I couldn't quickly find a good source on the web about these fans. If I would have found one I would have included a link. The best I could do was the illustration.
the instructions were so useful
iv decided to change my power supply fan because its noisy
but Ive bought 220 volt fans to replace them with the old one and connect it directly to the electricity
i want the fan not use the voltage generated by the power supply(12 volts) as i thought more voltage will be provided for my other devices
I m going to do this, can somebody give me advises on doing this?
thank u
What is the power rating (Watts) of the supply, and how many devices have you got attached? The fan doesn't draw that much current, you may be OK with a regular 12V fan.
By the way, the residual voltages can exceed 400V, depending on the line voltage in your country.
Yes, the yellow wire is the speed sensor, which was not used in my power supply.
