iImage Information
This instructable is a quick guide to build a 20 pin computer power supply tester out of parts from old computers and PSUs. The tester will also work on power supplies that have the 20+4 pin connecter. You can use this method to make a 24 pin PSU tester as well. Similar units sell for around $15-$20 but you can make one for pennies if you have the parts laying around like I did. The inspiration for this came when my friend gave me his old dead tester after he bought a new one.
Step 1Gathering the Materials
iImage Information
This instructable is meant to help save you money and keep people from wasting resources. All the parts I used (except the heat shrink) came from an old computer. This is just one of many things that can be built entirely from recycled components. I intend to use every piece of material from this pc. Every computer that goes bad i take apart and strip out all the working components before sending the rest off to be recycled or disposed of properly.
Be careful de-soldering! If you heat up the pins in the power connector too much it will melt and deform the plastic. I have unwittingly done this before.
Materials:
button or switch (as long as it is not momentary)
LED
2 wires (same length, however long you want it)
20 (or 24) pin connector socket
solder
I would have done the following:
Grab connectors from old PC. These must include: one female 4-pins molex, one female SATA power connector (from a dead SATA drive), one 6-pins molex connector (salvaged from old GPU with such a connector) and of course a 24 pins ATX power connector.
Each of these connectors carry the same voltages, so along with testing the PSU rails, you will also be able to test if either a cable of connector itself is not working.
The next step is to make a small "circuit" that collects all the similar voltages from each connector and joins them together, so that you end up with one +12V, one +5V, on +3.3V and one -12V rail. To these, hook up a resistor of appropriate value (to drop the voltage enough) so that the LED you will add does not burn. This will only however not test the PSU under load; it will merely indicate that the rail is providing right now the correct voltage (assuming the LED is lit).
In order to truly test a PSU, you must measure the voltage on each rail of the power supply, when it is under load (important). Therefore, instead of a resistor + LED like in the previous step, I would recommend taking a high power resistor feed by the power supply. Then, make terminals (usually, simply a bare wire) so that you may easily measure the voltage using a multimeter. Be careful however about the resistor values - for example if you want to test it under a load of 25W, for the 12V rails, you would need a resistor of about 5.8 ohm, which will draw a current of about 2 amps, which is kinda a lot. The resistor will also get very hot - this has to be expected.
Keep in mind, this (very) long comment should NOT be used as a straightforward guide to make a PSU tester, rather it should only give you the basic idea behind it. A computer PSU can provide a HUGE amount of power, which can be very dangerous if the tester is not made properly. I will probably make a proper instructable about eventually, including safety aspects of it.
Hope this can help anyone out.
To make such a device, all you need is Ohm's Law and a couple of (high) power resistor. Also, plan something to dissipate an immense amount of heat (about half of a toaster) because those thing will get HOT.
Now let's say you bought a cheap PSU that's rated 400W. Let's assume one of the12V rails has maximum of 20 amps. According to Ohm's law, you would need a 12/20=0.6 ohm resistor to have a current of 20 amps. That's 240W, that's A LOT. But if you can have your hand on high power resistors and make a combination that is around 0.6 ohms, you could seriously test if the PSU would handle it. Again I don't expect anyone to do if you have no experience with this. Those who can do this will already know how just by reading this, the others shouldn't bother.
Many cheap PSU available for very cheap are of that kind, and the wattage advertised is really nonsense. Sometimes, the makers imply that the advertised wattage really is the peak wattage of the device, which is useless.
This is a good page where a qualified dude explains what happens with cheap power supplies and what's different in a good one. He also blows one, by merely loading it with something _lower_ than the rated value.
Thanks for the information.
L
L
Check the "Signal Lines" section of http://www2.mmae.ucf.edu/wiki/ATX_Power_Supply_Mod
