3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cheap (AXT) Bench Power Supply 30 Amps!
  • last photo ←
This is my second PSU (Power supply Unit) as my prievieous one mysteriously burnt out (!)
I managed to purchace a new Computer PSU to convert, this one has a nice jucy 5V at 30A! and 12V at 21A!
I also managed to get a 30A panel Ammeter Yay!
Any comments welcome!
(Plz dun be too harsh lol)
Enjoy!
20 comments
Apr 14, 2011. 11:18 PMQuackoman says:
the ammeter you found looks good but if the max out is 30A you should have gotten an ammeter that can read just above btw it looks very neat.
Jun 17, 2010. 4:13 AMAngelLaHash says:
Personaly i just got a light switch and hooked a ATX connection (24pin i think) to one end and 5v/12v on the other.. that way i figured i could use any ATX PSU i wanted. I love the Amp meter tho .. maybe write what connector is what on the case.
Dec 20, 2009. 1:23 PMkiiko says:
hehe cool, your tabel looks like mine ^^. lods of fun stuff
Oct 16, 2009. 8:29 PMpjharro says:
Would you please be able to briefly explain your wiring? What do the lights do?
Thanks
Sep 29, 2009. 9:18 PMbumsugger says:
Looks good,any chance of a ctt. diagram,plus a few "build" details??
Sep 28, 2009. 7:39 AMbikedude880 says:
*cough* ATX *cough*
Sep 26, 2009. 10:02 PMmikedoth says:
Don't most home circuits only supply 15 amps?
Sep 28, 2009. 9:52 AMcpotoso says:
At 120V, a good power supply has a pretty good energy efficiency. Power = Voltage * Current (roughly speaking, there are some refinements needed for AC). Hence, 5V * 30A = 150 W, only ca. 1.3 A at 120 V, say a bit more because of inefficiency, still leaves things well-below the 15 A...
Sep 27, 2009. 5:36 AMjhines0042 says:
Yes, 15 amps at 120 volts AC in the US anyway. Sometimes you will find 20 amp wall service, the outlet has a separate little tab cut into it to indicate.
For the rest of the world, check this page on wikipedia:
http://en.wikipedia.org/wiki/Mains_power_around_the_world
The thing is that the OUTPUT of the Power supply is not at 120 volts. So the amperage can be boosted as the voltage is dropped.
Sep 28, 2009. 7:43 PMmikedoth says:
"So the amperage can be boosted as the voltage is dropped." How in the world is this possible?
Sep 29, 2009. 3:43 PMjhines0042 says:
This link has a great explanation of this exact principle.
http://www.allaboutcircuits.com/vol_2/chpt_9/2.html
Basically if you cut the voltage in half with a transformer you necessarily increase the amperage by a factor of 2. A mathematician would say they are dependent variables.
Sep 28, 2009. 3:54 AMjhines0042 says:
I knew what you meant, I was simply trying to help clarify your point. Nice instructable, btw. I will probably make one of these myself at some point.
Aug 17, 2011. 9:19 PMtstreet1 says:
Dude, you should post a link to your flyback driver. I'd like to check it out.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:muttyfutty
A li'l kid from Inkland (England if you can't take a joke) High voltage is awesome, so is pie. Lemon Pie is good. The Beatles are the best, end of story. Have a nice day! :P I'll probably add more lat...
more »
