Remove these ads by
Signing UpStep 1: Fabricate the Handles
Next I drilled two ½” diameter holes approximately 1” deep on the same side of each handle blank near each end. I used a forstner bit to make neat clean holes with flat bottoms.
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
However, I have some misgivings with this reply.
1. I have an iPad-2 and the audio jack, the microscopic Microphone hole and the Power Button on the top edge will be inside the slot in the wood.
2. the charging power comes in via the large Apple-connector, which is used also to connect to the USB port in a PC.
3. The only controls that I see accessible while the ipad is "in the dowels" is the lock and Volume buttons.
So, with regards to Kiteman's question, you would have to disassemble the unit to recharge it.
#2 connector is on the bottom edge of the iPad-2
I realized that the author did not say "ipad", he said "Tablet", which could be a different brand and device.
So, ofr my iPad I would have to disassemble for recharging.
Thanks a million times over~
Connie
Floyd
Build_it_Bob
Same thing in silicone material could be nice too.
00923244869715
Thanks for the comment.
