Computer Water Cooling System
Introduction: Computer Water Cooling System
Hello. I'm Korean living Korea.
I like looking So many instructables in this site and making my own.
today I like to introduce my Computer Water Cooling System - it's my own design!
It was made at 2008.october
I don't have any confidence in my English so will show you many pictures with lesser word.
Step 1: Radiator
I used Oil Cooling Radiator for car.
I went Hyundai motor shop and bought new but if you want to get cheaper one, can get in an auto junkyard or auto repair shop.
the radiator is aluminium so easy to cut and tap.
and some plastic two touch fitting - to avoid Galvanic corrosion
Step 2: Making Body
Foamex is very good to making something.
Cheap, various thickness, easy to cut, easy to glue
with cyanoacrylate bond, can make very fast
Step 3: Making Body Step 2
Now Look Pictures Carefully please.
I used Some technique but hard to explain all in English.
Sanding Edge 45 degrees makes look good when two plate stick together
and some little across tooth makes two plate are in same plane
Step 4: The Face
I don't like easy, simple Instructables anybody can do.
To make special system, I designed face in 3D cad program.
(could more complex design but it means hard to make)
Step 5: The Face Step 2
I prefer polyester putty, but this time there was only epoxy putty.
wet sanding is more better than dry sanding
Step 6: Painting
Painting and lettering.
text is Dry Decal.
Parkoz is biggest Computer community in Korea.
One man in parkoz tuning forum made fan controller board named parkoz controller.
-can control 4 fan speed(auto/manual)
-can display 4 temperature
-compatible several character lcds
-full speed fan when staring
... etc
it's some big and oldie cause made before several years.
Step 7: Test and Fix
12V Thermaltake motor was not good. weak and noisy.
Changed cheap(about 4$) aquarium motor. quiet and powerful.
New motor means new water tank.
Motor need 220V so used SSR(solid state relay-non mechanical parts) for switch.
Step 8: Fix Again
Oh no.....
Parkoz Contoller doesn't work in test suddenly...(crying)
I tried fix it but can't so replace with Parkoz Controller II!!
More little, More Powerful now. :)
Step 9: Installing Jacket
Installing Zalman water jacket.
It's full Aluminium so don't worry about Galvanic Corrosion.
Step 10: End
Finally done.
I thought some LEDs to put in but sooooo tied at that time.
it works good. full load temp is about 45' and about 35' at normal.
forgive my awful english(but I tried). and Thanks for reading ;)
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    • Pocket-Sized Contest
    please have you the electric schema? thank you in advance
    sorry, it was Co-produced by forum members long time ago.
    No material was available at the time.
    That's called perfection.......and you dont find that in most of the diy of all diy water cooling system i've ever seen......better than the one i made.......btw what are the specs of ur gig.....????
    You did an amazing job and i like the fact that you used lots of photos.Thanks for your contribution.
    hi pashiran i really want to know. where can i find a water block ????
    Id have to agree. Trust me your English is better than a lot of people. And the case is amazing.
    Love the front panel, nice 'ible
    do you mean my own pdf(not-instructables)?
