Remove these ads by
Signing UpStep 1Safety First!
This instructable is intended only for someone experienced and confident in wiring high voltages. Do not attempt to do this if you are not. Household current can kill or badly injure you if you who do not understand the danger.
Only the U451 relay contacts should be used for control/connection to 110V AC. The relay screw terminals are isolated from the other circuit connections. DO NOT touch the U451 when there is 110V AC present.
PCB trace widths limit the connections to the relays to about two amps - this should not be exceeded.
The board is what's limiting it, not the relays. Probably not that hard to work around if necessary.
Similar to mine at:
http://www.instructables.com/id/Yet-Another-Arduino-110v-Power Controller/
Mine does not use a relay board, so it is not for the faint of heart :-)
Best Wishes
http://www.instructables.com/id/Yet-Another-Arduino-110v-Power-Controller/
RobotBASIC comes from http://www.robotbasic.org
http://www.circuitgizmos.com
http://www.dontronics.com
http://strandcontrol.com
... sells them.
