3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Computer controlled OTA TV antenna.
Parallel port add-on to set the direction of an antenna. it could be used for most any antenna, but I did it for the hdtv antenna (http://www.instructables.com/id/Yet-another-dtv-antenna/).
Note: This instructable requires programming. I did not include my code for legal reasons.
Warning: Please be careful with this project. Not properly hooking wires correctly could cause shock and or even death. You could also damage your computer and other electronic parts. Please get a professional electronics technician to help if you are not sure what to do. . Please use a breadboard first before doing any soldering. Get expert help if you are not sure.
Step 1Whats needed:
Computer:
PC with parallel port.
Linux (can be easily done on MSWindows also)
Freebasic compiler (available for both mswindows and linux)
Parts:
1 - 5 wire stepper motor from an old 5 1/4" floppy drive (or equivalent).
1 - 1 x 1 inch square flat plastic for mounting tube.
1 - parallel port breakout cable (i.e.http://www.instructables.com/id/No-solder-parallel-port-break-out/ or http://www.instructables.com/id/Mini-parallel-port-break-out-cable/) or an equivalent.
1 - OTA TV antenna ( i.e. http://www.instructables.com/id/Yet-another-dtv-antenna/)
1 - 1/2 to 3/4 inch two foot pvc pipe. low pressure pipe is ok.
2 - 1/4 inch screws (long enough to go through pipe and the antenna, 4 washers, and 2 nuts,
1 - uln2803 or equivalent integrated chip (i.e. nte2013)
1 - socket for the above chip.
1 - small plank to hold stepper motor steady.
Solder
Glue
Wire
Optional: breadboard for testing circuits before soldering (recommended)
Tools:
Multimeter
Compass
Saw
Soldering Iron
Other website information to be named later.
7 comments
Jan 26, 2011. 4:26 PMkd1s says:
Or you can order a stepper from the likes of MPJA, Sparkfun, etc.
Apr 14, 2011. 11:59 AMLectric Wizard says:
Nicely done, & well explained for the newbies ! Just something I noticed in the second pix in step 5 , should the chip be labled uln2803 not uln 2003 ???. THANKS !!
Jan 31, 2011. 6:15 AMchrwei says:
is that a Commodore monitor? I spent many hours as a teen staring at one of those
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
66
Author:Computothought(Computothought)
Educator, technician, unchef, and chief bottle washer. Be sure to see http://www.instructables.com/community/Computhoughts/ for updates and status on projects.
