Computer Monitor Led Strip
1,439
4
Published
Introduction: Computer Monitor Led Strip
this is a tutorial about led strips behind your monitor/tv.
it`s very easy to make and it costs (for me) 20 € / $ / whatever. i am not responsible for your stuff that is broken by this project, safety and other things like this. this is at your own risk!!!if you`re pro at this stuff you know it better, but i am just an amateur and i try things like this.
Step 1: The Suplies/things You Need for This Project
soldering iron, solder, wire strippers, electrical tape, wire cutters, led strip and adapter(9v DC)
Step 2: Led Strip
cut the led strip to length. it needs to be a little bit smaller(about 5 cm) than the monitor/tv.
Step 3: Stripping the Wires.
cut the end of your adapter. take your wires from the adapter and strip 5 mm at the end. do this with both wires.
Step 4: Soldering the Wires
solder the two wires from the adapter to the led strip, make sure you have the right polarity.
Step 5: Taping
wrap your solder in electrical tape.
Step 6: Monitor/tv
stick the led strip on to your monitor and plug your adapter in to your socket. the led`s should light up.
    • Woodworking Contest
      Woodworking Contest
    • Planter Challenge
      Planter Challenge
    • Make it Move Contest
