Remove these ads by
Signing UpStep 1Disassembly
The uncorrupted min-fridge is really a splendid gadget. By reversing the polarity one can turn it into a mini heater. I installed a diode after some testing to make sure that was imposable for me! There are several brands and makes of mini-fridge out there, but they all probably use the same vendors for the peltier as there are few manufacturers. One thing to closely look for on the packaging is the power information. All the mini-fridges we looked at had some form of watt consumption on it. We got the biggest ones we could get in this unit some where about 65 watts each.
So our next step is to start liberating the peltier from the housing. When I started this step I thought it would be real easy... boy was I wrong. They used those damn torqs type screws with the post in the middle of them so none of my torqs drivers would work. And additionally they also used one of the longest drivers I have ever seen in an s-mart tare apart. I ended up just taking the darn thing and getting a 1/2 inch drill bit so I could just drill out the holes and there for the posts in the case. After that it was just a matter of jumping on both sides (causing the deformation to the sides you see) and then some mild expletives while trying to remove the Styrofoam with out making a nightmare level statically charged mess. But with that all said I found out that sears had the tool I needed for about 5.00 or so. meh... so if you do this... you can choose the road you travel. |
The peltier is attached to an aluminum pan with 4 small normal Phillips screws, and was relatively easy to remove. There is a thick layer of thermal compound on the cold plate that is sandwiched between the peltier and the aluminum pan. We want to leave the cold plate attached there for us to use, but every drop of the thermal grease must be removed. Not even the slightest film of it can remain or future steps will not go so easily. Using some rubbing alcohol and a nice cloth, or a old sock, and preferably some Q-tips clean every last speck off of the block and your good to go. Additionally, there is a small thermal resistor inline next to the block on the negative side of it. Cut that baby out as you want your cold ones nice and cold. |
The thermal take chassis. This is a really nice case. One of the nicer things about this case is the lock you can see there on the side. This means you can keep your cold ones cold with some security from room mates or peeps in your dorm room. |
| With the key turned one way it locks the whole chassis, middle lets the main front door open, and turned the opposed way from the locking position lets you open the whole front bezel like a door. We will be doing a lot of modification to this area to accommodate both a dispensing hole, but also a way to refill the fridge as well. |
So here is our side view. Everything in this case is aluminum, as it should be! The hard drives have a removable tray as does the floppy. Those and all other internal goodies like fans and cables will need to be gutted to make room for the stuff we want to do to this case. |
The main internal structure for this case is held together by aluminum rivets. The only way to remove these beauties is to drill them out. Using a 1/8th inch drill bit, make sure you get a good self tapping metal bit. (that's the medium your drilling into, although if your interested in a bunch of drill bits made out of wood leme know, I also have a nice bridge in Brooklyn for sale.) |
So here is the case all gutted. With all the internal structure removed there is a lot of space available inside for all the other work we need to do to this. |
So the final step we need to take in this fab process is to put a nice big hole in the top of this case for the power supply to breathe through. Using an 80mm hole saw we got at the local hardware store measure and drill a pilot hole where the power supply's bottom fan should fit. using the hole saw in reverse in aluminum helped it start into the metal with some ease then put it back in forward mode to finish off the hole. Fair warning, hold your case and drill very tightly as aluminum is very soft and doesn't mend well from dings and scratches from a hole saw bouncing across the top of it. |
comment
Add Comment
admin
says:
Add Comment
