Introduction: Computerized Spinning Button
Picture of Computerized Spinning Button
While sitting around spinning a button on a string, I realized that this was not the best use of time.  By utilizing the power of the Arduino, along with a servo motor, battery and 3D printer; I was able to take this task--which a small child can do--and automate it.
Step 1:
Picture of
Take a 20 inch long piece of 1 1/2 inch OD acrylic tubing along with an HS-311 servo motor, Arduino Uno, and 9 volt battery with holder and integrated battery switch.  Add a printed button, string, end pieces and servo motor holder.
Printed parts and design files can be found at:
http://www.thingiverse.com/thing:123939
Step 2:
Picture of
Insert the end pieces into the tube.
Step 3:
Picture of
Add the servo motor holder.
Step 4:
Picture of
Drill out the end of the servo horn so that a piece of string will fit.
Step 5:
Picture of
Insert the servo motor and servo motor cover.
Step 6:
Picture of
Run string through the button and both ends.  Cut and tie.
Step 7:
Picture of
Wire according to the schematic.
Program the Arduino with the following  complex code:
#include <Servo.h>
Servo button;
void setup()
  button.attach(7);
void loop()
{button.write(30);
delay(500);
button.write(105);
delay(500);
Step 8:
Picture of
Wind the button up and turn on the switch.
Now, your days of tedious button spinning are over!
Build_it_Bob (author)2013-07-29
I remember many years ago when my dad made me a "buzz saw" as he called it ...you just took it much , much further !
Nice!
Build_it_Bob
Thanks for the comment! I'm not sure why this is fascinating to operate, but it is. Of course, the larger the button's diameter, the easier the process is. I just got curious as to whether this could be automated, so I gave it a try. The Arduino code has to be one of the shortest software listings I have ever written that does anything.
About This Instructable
1,077views
3favorites
License:
Bio: I am an author and a maker. My current project is Santa's Shop. I'm working on a science fiction type book--more later. @EngineerRigsby
More by MikeTheMaker:Voice Recognition and Speech With Arduino ShieldSanta's Shop 2017, the TrainSnowflake Gear Wreath
Add instructable to:
