Concealed Carry Tips - How to Clear Handgun James and Other Malfunctions
Published
Introduction: Concealed Carry Tips - How to Clear Handgun James and Other Malfunctions
About: AlienGear Holsters makes concealed carry holsters. Voted the best IWB holster on the market today. Take a look at all of our gun holsters we offer - http://aliengearholsters.com
In this episode of Concealed Carry Television (CCTV), Alien Gear Holsters’ Chuck Hupp will cover several common firearm malfunctions and how to clear them. Check out more from Alien Gear Holsters at http://aliengearholsters.com/
Chuck first begins by explaining the “Failure to Fire” or FTF malfunction, which happens when you pull back the trigger and the gun neglects to fire. This may happen for several reasons, including a dirty gun or incompatible ammunition.
To troubleshoot this issue (for lack of a better term), rack the slide and attempt to make way for another bullet in the chamber. This may work. If it happens again, it could be the type of ammunition you’ve used in your gun. Also check the magazine. See if that helps your FTF malfunction.
If you’ve shot a variety of pistols, there’s a good chance that you have ran into the ever-common “Failure to Eject” malfunction, which happens when your spent casing does not come out. A common reason for this is due to a “Stove Pipe”. This happens when the spent casing becomes lodged in the ejection area. It becomes jammed in the slide.
The casing may also expand inside the barrel. You may want to invest on an AYOOB Dejammer.
Chuck also advises that you check your ammunition to assure that it is not considered an “underpowered round”, which will prevent your gun’s slide from making a full cycle.
If you run into a Squib load, use the AYOOB Dejammer after you’ve released the magazine, opened the slide, and looked through your barrel. Be sure to put your handgun in an Alien Gear Holster, the most comfortable and concealable holsters on the market.
Also check out the new IWB holsters at http://aliengearholsters.com/iwb-holsters.html/ and join the concealed carry evolution! Thanks for watching this episode of CCTV. Please ‘like’ and subscribe to our channel!
We are social always staying on top of all the gun news and concealed carry changes that come about follow us on.
https://plus.google.com/+Aliengearholsters
https://www.facebook.com/AlienGearHolsters
https://twitter.com/AlienGHolsters
    • Casting Contest
      Casting Contest
    • Outdoor Fitness Challenge
    • Woodworking Contest
      Woodworking Contest
    2 Comments
    Good tips, thank you for sharing your video.
    Glad you Like it, we have lots more in the works stay tuned.
