iImage Information
This is a piece of round stock into which I have drilled a hole that is perfectly on center. I could have made the hole as deep as my drill bit is long, but left it shallow. I did this on my radial arm saw. What I am demonstrating in this Instructable was inspired by a chapter in the Foxfire Books on boring the barrel for a Kentucky flintlock rifle.
Step 1Features of a radial arm saw
iImage Information
My radial arm saw has a 1/2 x 20 threaded shaft on the backside of the motor. Not only can I attach a saw blade on the front side of the motor, but I can attach a drill chuck or a sanding drum on the backside end. Further, I can swivel the motor so the shaft runs parallel to the saw arm. Because the motor moves along the arm on a suspension track, I can pull the motor into something I want to drill. That would move the motor and bit nearer to the left side of the photo.
I cut a piece of wood 2 x 3 inches a little over 5 inches long and aligned it under the drill bit so it is parallel to the drill bit.
As for the speeds is it the same or is there some kid of gearing?
As I mentioned, the Montgomery Ward and Sawsmith saws have a second parallel shaft with a mechanism for adjusting the rpm's of that shaft.
I have a recently acquired 9" Sears radial arm saw. It has the brake mechanism on the motor shaft opposite the blade. I used a block of wood to lock the blade/motor shaft, and removed the brake with the same wrench used for the saw blade. Under that, there is indeed a threaded shaft. I have yet to ascertain the thread size, but I'm betting it's 1/2 inch.
thank'you
The beauty of the books is that a lot of crafts and skills would have been lost with the passing of these people. Even though there is no real need to make a chair from woven oak caning, it is a great challenge to do it and teaches you a lot about materials and methods.
I believe the medicinal cure you write of was drinking kerosene, not gasoline. Although, it is not much better. Kerosene has also been the fuel of choice for fire-breathers.
At least they are widely available.
This is hardly my favorite Instructable of those I have done, but people seem to have taken to it. Maybe the title is a teaser suggesting something that just seems impossible. I pray my Instructables will be a blessing to someone and am thankful to be able to do them.
rob2024
I usually drill a 1/8th inch hole down the entire piece of wood. It is usually not concentric. Then I chuck the wood on the wood lathe and turn the outside down to a cylinder.
Voila!
This my two cents: You might get a straighter hole if you bolted the drill to the table, then mounted the dowel to the saw. And use a boring bit with one cutting edge instead of a drill bit. That way, the hole would be concentric, but possibly conical, instead of a non-concentric cylinder.
When I needed to drill a 1/2" hole into the end of the banner pole, a) I did not have concentric drilling attachment for the lathe, and b) the banner pole was longer than my lathe bed.
I have seen the bit wander because of the grain. I did not have that problem when i bored the banner pole as shown in this Instructable.
Thanks for your comment.
Take the tail stock off and mount the wood on an apparatus similar to your cylinder holder. Then chuck the boring bar or drill bit in the lathe head and advance the new "tail stock". That way, the cut is always concentric, but it may be conical :(
You have some fantastic ideas.
You could add a clamp such as this one from Rockler to make sliding the jig easier and help with alignment:
http://www.rockler.com/product.cfm?page=16448
I expect you saw other special tasks I have done with a radial arm saw. If not, just search by means of "radial arm saw."
or a drill press vise like this one http://www2.northerntool.com/hand-tools/vises-clamps/item-153813.htm would allow for rather easy adjustment for any one-off holes you want to make.
or if you only want to bore center holes in round stuff, you could get a self centering chuck like these http://www.workholding.com/FINDSELFCENTERINGCHUCK.HTM
I'm curious as to how level a typical RAS is likely to be mounted in a home user's shop. Besides the concentricity issues you discussed, if the throw of the saw is not exactly parallel to the table top, you won't get a good hold.
No, wait, that's not correct. You used the drill itself to make the holes in your jig. Therefore, those holes are (by definition) on-axis with the RAS's throw. If that's not parallel to the table top, that just means the holes in the two uprights will appear misaligned.
