3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Concrete Countertops for the Kitchen - Solid Surface on the Cheap
Step 3Building The Mold
Building The Mold
  • last photo ←
The mold is the most important part of the whole process, however it's also one of the only parts of the process that you can take your time with and rework if it isn't right. Make sure that every detail is thought through before you start pouring.
The best material to use to build your mold is 3/4" Melamine since it is perfectly smooth and straight and, if properly built, will hold water without swelling up. You'll need to use a tablesaw with a fine tooth blade so that it will rip down the melamine without chipping or splitting it.
The minimum recommended depth of a concrete countertop is 2" if you're going to add some sort of metal support for it. Since I don't have any significant overhangs, I'm just using standard concrete wire mesh. If your countertop is less than 2" thick, you risk having problems with "ghosting" from your supports - lighter areas in the concrete that are patterns of whatever metal you used.
We ripped several long strips of melamine down to 2 inches for depth and then used a miter saw to make our cuts to length. Then lay the template on the mold.
I CAN'T STRESS ENOUGH TO MAKE SURE YOU TURN THE TEMPLATE UPSIDE DOWN - YES, THAT'S RIGHT, THE TEMPLATE SHOULD BE FACE DOWN.
This is because you're pouring the countertop upside down. The top of your countertops will be the bottom of the mold. If you forget this step, as I did, your countertops will most likely not fit and might become a pretty little mini-patio in your backyard. Thankfully, I caught my mistake before the pour and was able to rework the mold.
We assembled the sides of the mold by predrilling holes every 3 inches or so then used a countersink bit so our screws would be flush with the top. The top of the mold needs to be perfectly flush so you'll be able to screed the concrete during the pour. Drywall screws are the easiest to use, but be very careful drilling them in. If you drill them too hard, they will split the melamine and ruin that side piece. This is especially so when you drill too close to the end of the piece. We reinforced the corners with blocks of scrap melamine since they would be under alot of pressure.
Due to the size of the island countertop I opted to do it in 2 pieces instead of one big one. There are a couple of reasons for this - one being that it makes it much easier to handle without an army of people. The other reason is that large spans of concrete are sensitive to shifting of weight over time and need intentional "stress fractures" (Go outside and take a look at your sidewalks). By separating it, you're ensuring that if there's any stress on the countertop, it will crack in the seam, which can be easily repaired and ground back down.
Instead of having a seam go straight through the middle of the countertop, I wanted to do it an an angle and highlight it with an aluminum strip. That way I could refer to it as a "decorative feature" instead of a "stress fracture". I bought a 1/8" x 2" x 12' strip of aluminum at Lowe's and propped up on the mold to decide what would look good, then marked it on the sides and template. We then used an angle guide to transfer the proper angles to the miter saw, where the sides and sink cutout were cut and then screwed in the mold with a 1/8" gap to allow for the aluminum strip to slide into the mold.
Another challenge was a big curve that I wanted to put in the countertop for a little barstool nook. To accomplish this, we cut the desired curve with a bandsaw out of two peices of melamine that were screwed together. We then took the two side pieces of melamine that connected to the curve and used a table saw to cut a 1\8" by 2" notch in each of them. We cut a piece of 1/8" piece of plexiglass down to 2" then prepared to glue the plexi into the notches we cut in the 2 side pieces. Before you try gluing plexi to anything, it needs to be sanded so the glue will stick. We used 5 minute epoxy to glue the plexi in the notches and clamped them. After that set, we had 2 side pieces with a flexible piece in the middle that would conform to the curve we needed to make. We screwed in the curved melamine into place and spread epoxy over the back side of the plexi. We then bent the plexi around the melamine, clamped it into place, and then screwed the 2 side pieces into place.
I wanted to have curved corners on the island so you wouldn't impale your gut if you walked a little too close. To do this, we took 2" PVC pipe and cut it into 1/4th with the band saw. By using a belt sander, we were able to sand down the edge till they were paper thin on either side. We then used epoxy and taped them down in the corners. This worked like a charm and was part of Mr. P's evil genius showing through. Mr. P Note-Evil is as Evil does-etoN P .rM
The last detail is a cutout hole for the faucet. One thing to keep in mind is that most kitchen faucets are made for 1.5" countertop depth. Not only is my countertop 2", but there's another 3/4" of plywood below that. For the cutout, I used PVC that the OUTSIDE diameter was smaller than the base of the faucet, but was big enough to get the hoses through. I cut it to 1.5" in length and then used a piece of 1/2" plywood circle so that when they were attached, they would be 2" tall. This allowed for a proper depth for the faucet, while also giving access for wrenches to screw it down.
9 comments
Feb 9, 2010. 1:03 AMRonnyM82 says:
just wondering if anyone knows what glue was used to bod the sides of the mold to the base? it looks like some kind of sika.... is there any risk of gettign a reaction between the glue used and the cement?
Feb 9, 2010. 8:41 PMRonnyM82 says:
yeah stpuid question actually, since you need to break it apart afterwards. i was thinking that you used caulk to join the two together.
On another note, since i am based in New Zealand its quite expensive for us to buy the premix from the cheng dude. So i was wonderign if you could point me to some good resources on the web to find a suitable recipe for the mix.
Nov 22, 2010. 7:13 AMstorm226 says:
there's a guy on the web that I bought a great manual on how to make a concrete countertop, he gives you the right mix to buy and he talks about what to do if you are out of the U.S. and can't find the cheaper supplies they have here. his name is Pete Hawes and his website is doyourownconcrete.com
Apr 11, 2010. 1:57 PMalbailey says:
Ronny, I highly recommend you get Cheng's book, which is referenced in the Intro. It goes into great depth on all aspects of creating a countertop, as well as Cheng's standard mix, broken down by weights per cubic foot.
Aug 15, 2007. 2:15 PMfarmcarp says:
doubleb, This is really impressive. I'm getting ready to do a countertop myself, and your instructable is about as helpful as Cheng's book and DVD. I noticed you used a 4x8 solid piece of melamine as the bottom of the mold, breaking ranks with Cheng, who recommends cutting the bottom of the mold. I was considering doing the same thing. Did you find it difficult to attach the side pieces to the bottom piece of melamine? My feeling is that it would be difficult to keep the side pieces in the right place while you predrilled and screwed. How did you overcome this, or was that even an issue for you. Also, the rounded corners with the pvc, nice touch. Is that 2" diameter pvc pipe that you quartered and sanded? Great project, I bet you're really happy. I just poured 3 16" x 24" samples last night to fine tune the color, as well as experiment with mold surfaces. I'm testing melamine, acetate, and something called tile board (looks and feels exactly like a white dry erase board). I'd like to minimize the grinding and polishing. By the way, is any grinder available at Home Depot or Lowe's or other hardware stores suitable for grinding concrete (assuming you add water). What attachments are necessary to buy with a grinder? Sorry for the long post.
Jun 3, 2009. 9:28 AMportalvcia says:
What was the outcome of your mold surface testing? I am planning to build a mold...but want to minimize cost , as I am unemployed right now....figures, right? When you have the money , you dont have the time....when you have the time....no money!
Jun 4, 2009. 7:21 AMfarmcarp says:
I ended up using melamine. It was the simplest and best performing material I tested for the mold.
Apr 2, 2009. 2:19 PMbarncat says:
Make sure you're grinder is a variable speed. The discs are expensive and you will benefit from the slower speeds. definitely under 4k rpm and right about 2500 is what I am discovering. I still need to experiment more but that may be a helpful starting point.
Apr 2, 2009. 2:20 PMbarncat says:
rpm? I'm not really sure what the rating is but the 2500 part is sound.
Sep 4, 2008. 1:53 PMGrendal says:
From Mr. P.-we used Irwin Bar Clamps to hold everything in place. dbl A would pre-drill the holes and I would follow with a countersink bit. We would then carefully place the screws in with a battery drill set on low torque. The tough part was not drilling to deep into the side of the Melamine which may crack or distort it. Like you our goal was to sand and polish as little as possible. We could not find a grinder we liked locally-However the one we acquired via mail order needed a air compressor of such high CFM that it was pretty useless. We did not at the time have a high CFM compressor. Note in previous discussions the difference between PSI and CFM is significant in cases of sanders and air guns where continuos use is critical. The PVC is 2" if i remember correctly, dbl a wanted a certain radius on his corners and I think I had that pipe sitting in my shop. We sanded the edges to make them thin again to reduce sanding. I imagine if you wanted greater or lesser radius any diameter within reason would work. Keeping the PVC in place was a little tricky. We taped and backfilled the spaces to support the corners and keep them as straight as possible.
Jan 21, 2010. 7:13 AMljq77 says:
Do you know about how much making a concrete countertop costs?  I have about 40 sq. ft.  Also, could you shelac the melamine before you pour and maybe it would turn out smoother.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
60
Author:doubleabattery
