3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Concrete Countertops for the Kitchen - Solid Surface on the Cheap
Step 4Preparing The Mold For A Pour
  • last photo ←
Preparing the mold properly for a pour is essential for many reasons:
1. It needs to be watertight so that it will hold the wet concrete without leaking.
2. Every detail in the mold will transfer to the countertop. Even the slight texture on the melamine will be the same texture on the countertop when you first break the mold.
3. It must be supported well and level. You will be pouring hundreds of pounds of concrete into the mold, so you must make sure it doesn't buckle or bend under the weight. Also, you're going to need to vibrate the concrete, so it needs to be screwed to its support.
4. The concrete will start setting in 30 minutes. You'll need to work fast once the concrete is mixed so you'll want to make sure the mold is fully prepared.
I don't have any pictures of this, but you'll need to properly seal the mold using silicone caulk. I used black caulk so you could see it against the white melamine. You want the caulk to have extra clean edges, so I used blue painters tape on either side of the seams, backed off about an 1/8". After you apply the caulk, carefully remove the tape before it dries and you'll have super clean edges that will require minimum grinding. You'll want to let the caulk dry overnight.
You also need to make sure that any cut sides of melamine that will be exposed to wet concrete need to be sealed so they won't swell up with moisture. To do this, I sprayed spray adhesive on the exposed edges, then put down clear packing tape on it. I trimmed the excess tape with an exacto. To avoid getting excess spray adhesive in the mold, I used a straight piece of cardboard to shield the overspray.
The tape covered up most of the screw heads in the mold, however there were some that were still exposed. Since you need to remove the screws to break the mold, make sure that any exposed screw heads are filled with some type of clay or putty (plumbers putty, plasticine clay, etc.). This will avoid the concrete getting into the screw heads, making it next to impossible to unscrew them.
To support the mold, I used 2 very stout sawhorses with 2 sheets of 3/4" plywood stacked on top of each other and then drilled into the sawhorses. I then laid the mold on top and screwed the edges of the mold into the plywood. For added support, I took some scrap pieces of wood, cut them to size, and screwed them in around the edges of the mold.
I didn't have any significant overhangs with my countertop, so I didn't use rebar to support it, however I wanted more support, so I used 2 flat sheets of concrete wire mesh. I cut them to size then stacked and offset them, tying them with wire. You'll also notice I stacked two pieces of styrofoam to make 1" spacers off the bottom of the mold. Remember that if the wire mesh gets too close to the bottom or sides of the mold (which is the top of your finished countertop), you will have problems with Ghosting. By using spacers, we're ensuring that the mesh will be halfway in the middle of the countertop. Also make sure the mesh is 1" away from all edges of the mold.
Now that I had the support cage made I lifted it out for final preparation. First off, I vacuumed the mold and cleaned it thoroughly with rubbing alcohol. To add further personalization to the countertops, I wanted to embed coins from places that my wife and I had traveled to. This was easily accomplished by rubbing a bit of caulk on the side of the coin I wanted exposed and arranging them face down on the mold. The caulk gives just enough adhesion to keep the coin in place during the pour and I didn't have to wait for it to dry. Mr. P Note-Remember the side of the coin that is facing down will be exposed when the countertop is finished-in other words the side you put the silicone on will be exposed.-
The next step was to put the styrofoam spacers back in the mold, lay the cage down, and then tie wire to support the cage once the spacers were removed. I put screws around the outside edges of the mold so I could tie the wire around around the heads and then wrap them around the edge of the cage. Once all tied off, I slid the spacers out from under the cage which wall now suspended off the bottom of the mold.
The other addition to my countertop was to have crushed blue glass in it which matched my blue glass mosaic tile in the kitchen. I purchased the glass from Cheng, however you could crush your own glass if you like. The directions suggested spraying spray adhesive on the mold so it will be tacky before putting down the glass. I did this and even though it doesn't stick the glass very hard, it makes it tacky enough so the glass won't pool together when the concrete is poured. Also, make sure the tip on your can of spray adhesive is clean. Mine wasn't and it put little bubbles on the mold which transferred to the countertop. I then dispersed the glass as evenly as possible.
I was now finally ready to pour!
10 comments
Jan 24, 2008. 3:02 AMeagle1 says:
Good illustration. One question about crushed glass. You said we could crush our own glass, is this a special type of glass or just my regular "Ice house bottle". If it is the regular glass, will not end up being dangerous once on the counter. Please advise on this, i will try this by the end of next week.
Apr 4, 2011. 7:50 AMrubyintherough says:
Do you have any hints on how to clean the labels off glass that's already been through the crusher at the recycling center? They'll give me all the glass that I can use, but it's still got the labels on it.
Thanks for the great instructable!
Feb 7, 2012. 7:50 AMbhindbluizz says:
Don't know if this will help but I use Goo Gone, it will remove labels, glue, chewing gum etc. You can buy it almost anywhere.
http://www.googone.com/
Oct 31, 2011. 7:51 PMrobbhammack says:
This is probably to late to help you, but for anyone who's worried about super sharp broken glass, cleaning it, etc. just get a bag of sand, mix it with the glass, and run the mix in your cement mixer for a few hours. this should knock off / round over the sharp edges and clean off any labels/residue on the glass. obviously, the longer you let it run, the more rounded it will get.
Dec 22, 2010. 11:31 PMsir_eric78 says:
I guess I have the same question as the last guy, how did you separate the 2 sections with the metal in the middle? I would think both sections of the concrete would cure to the metal.
also, what did you use to place the two forms together durring installation?
thanks for any info
Eric
Mar 21, 2009. 7:32 PMtritech11 says:
Hi Mr P. Top Job mate. Jus wanted to ask you a couple questions as im in the process of setting up a mould for benchtop as well. When you put in the metal strip and poured, once the concrete had cured and you removed the mould, how did you separate the two island sections of your top, didnt the concrete stick to the metal strip? If you're able could you email me your response to tritech11@optusnet.com.au ? Thanks mate. Paul
Jun 3, 2009. 9:12 AMportalvcia says:
a shellac or varathane coating allows you to release the concrete from metal, and also protects the concrete from reacting to aluminum.
Feb 5, 2009. 12:31 AMrlmccarthy says:
How about mixing fiberglass strands into the concrete instead of using wire? i used that on a drive wayand it worked great.
Mar 12, 2009. 12:05 PMbschonec says:
I think you'd get a fuzz on the surface of the concrete if you didn't lay down a bit of non-fiberglass laden mix first..
Feb 22, 2009. 9:00 PMconcretepaul says:
Fiber are used by most professionals, some of us use PVA , nylon or glass as in GFRC (glass fiber reinforced concrete). Google GFRC you'll be amazed.
May 8, 2008. 9:09 AMSPAustin says:
Is the wire cage required? How did you keep it suspended 1" away from all exterior surfaces?
May 13, 2008. 5:48 PMconcretepaul says:
Some sort of reinforcement is needed and one of the best is remesh. You can get it at HomeDuh Poe. To suspend in a 2" thick piece, cut some foam or wood blocks 2" or so. Cut the grid about 1.5" short all around the mold. Lay the wire grid on the blocks that you have spread out in the mold. Now use drywall screws about 1.5" in length and screw them on the outside of the mold by the side pieces. I angle the screws out and leave about 3/4" sticking out. Then take some tie wire and wrap around the wire remesh, then over the side to the screw, wrap firm not tight. I usually do one on each side then I can pull enough to just suspend the remesh. I will usually tie the grid up about 18"-20" apart. After it is tied up and tight, then remove blocks It will stay in about the middle or higher. Ideally you want the reinforcement in the bottom 1/3 of the finished slab (right side up). I do not use rebar but instead I use allthread or threaded rod. More on that later if you want. Paul concretencounters@gmail.com
Apr 13, 2008. 7:40 PMKnucklez says:
how quickly do the grinding pads wear down? i.e. should i buy 2 x 50 grit pads for a standard kitchen counter? thanks!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
60
Author:doubleabattery
