Step 22. Pour Concrete
We used a full 60lb. bag of basic post concrete mix since we had that on hand. It worked ok, but cracked because the form was too thin (specs state minimum of 2" thick). The trick to a smooth final finish to knock all of the air bubbles out. We tamped everything well with a small stick. Then we beat on the outside of the form with a hammer. You will see the bubbles rise to the surface. Let sit for at least 24 hours. (we rushed it and cracked the main bowl. as an easy fix, we glued the pieces to plywood with liquid nailsback in business)
comments
Add Comment
Add Comment
