3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Concrete LEGO
Concrete LEGO
How to make your own 10:1 scale LEGO brick out of concrete!
You'll need:
  • 4 - 5 liters of concrete (when mixed)
  • Some scrap wood
  • Saw
  • Hammer and nails / screws and screwdriver
  • Ruler (or something else to take measures)
Step 1Messure up!
Messure up!
So, how large is a LEGO block?
These links ought to give us some clues..:
http://nobsjustabs.wordpress.com/2009/03/24/converting-lego-measurements-to-scale-lengths/
http://stason.org/TULARC/games/mindstorms-lego/13-Material-Technology-and-Measurements-Lego.html
To make a 3 x 2 brick we get the following measurements:
Height of block: 9.6 mm
Width of block: 15.9 mm
Length of block: 23.8 mm
spacing of knob centers: 8 mm
Diameter of knobs: 5 mm
Height of knobs: 1.7 mm
To scale this up, we just change "mm" to "cm". Easy, huh?
10:1 block:
Height of block: 9.6 cm
Width of block: 15.9 cm
Length of block: 23.8 cm
spacing of knob centers: 8 cm
Diameter of knobs: 5 cm
Height of knobs: 1.7 cm
92 comments
1-40 of 92next »
Jul 30, 2009. 8:48 AMdthorpe says:
To prevent the concrete from sticking to the form and make it easier to remove the form after the concrete is set, line the form with a sheet of plastic. Hefty garbage bags might suffice, or a bit of visquene sheet. Fold the sheet carefully in the corners to minimize unsightly creases in the concrete. To make a lot of these blocks, you should probably invest in making a few silicone molds instead of wood. They'll be more work and more expensive to make than wood, but should be much easier to pull off the concrete and should last longer.
Aug 2, 2009. 2:30 PMDeus says:
i think the concrete is too heavy for silicone, think it just stretches the mold instead of just filling it up.
Jan 29, 2010. 2:36 PMjust pick a name says:
They usually use a firm urethane rubber for concrete molds.  Smooth-on.com probably has a video or two of concrete molding and stamping.
Apr 1, 2012. 10:47 AMgutbucket says:
I used another instructable http://www.instructables.com/id/How-To-Make-Your-Own-Sugru-Substitute/ to make stepping stone molds from a plasticene over Styrofoam original. The 'oogoo can be layered on even after the base coat dries on the mold and if you are worried about stretching and strength, you can put fibreglass drywall tape down as you lay up the mold. The modelling clay original easily pops out of the silicone mold. This was an easy & inexpensive way to make unique stepping stones for a fundraiser. Btw those cement legos are awesome!
Jan 30, 2012. 6:54 PMjake14 says:
the easiest way to keep cement from sticking to the forms is to cote them with diesel fuel. when working with a local contractor we always had diesel in a five gallon bucket and used a paint brush to apply.
Jul 30, 2009. 10:05 AMvatosupreme says:
Another Idea would be to paint the mold with Krylon or epoxy paint. When dry, then spray the mold with WD 40 or Pam or some kind of cheap oil that will act as a release. Good project.
Sep 1, 2011. 3:00 PMvenom1539 says:
I thought stepping on plastic lego was bad enough.
Jul 29, 2009. 8:05 AMmadmanmoe64 says:
I was surprised to see this as, for the past couple of months, I've been working on a seating project similar to this. We had a budget and lot longer for development (we also had copyright issues to avoid) But I thought people might like to see what we did. We had to consider durability, mass production and re-use of the molds. I have hundreds more pictures if anyone's interested. Obviously these look slightly different to actual LEGO bricks but they stack properly :)
Aug 12, 2011. 8:15 AMmadmanmoe64 says:
btw I did eventually get around to making this into a full concrete seating instructable. http://www.instructables.com/id/Modular-Concrete-Bench/
Aug 11, 2011. 11:22 PMXOIIO says:
They look like those lego candie blocks XD
Aug 10, 2009. 7:01 AMthebriguy says:
Beautiful work. If they were rectangular they would be able to lock across blocks better/have more diverse use. Maybe make those in addition to these?
Aug 10, 2009. 4:09 PMmadmanmoe64 says:
Yeah, that would be cool. we didn't need the blocks to overlap for this project, but longer bricks would allow you to make more sound structures, if you wanted.
Feb 7, 2010. 8:04 PMthebriguy says:
There was a reply here I DID NOT POST (but it had my screen name). Anyone else have a problem with having their screen name hijacked?
Jul 30, 2009. 12:37 PMJoeStrout says:
I don't know about stacking "properly" — the first principle of LEGO building is "cross your lines" (that is, offset each row relative to the one below it so you don't have vertical interfaces running more than one row high through your structure). It doesn't look to me like these blocks can even do that, because the studs are too close together in the center and not close enough to the sides. Still looks like a neat project though!
Jul 30, 2009. 7:00 AMrandom-charm says:
I like this version a lot. Looks very clean, sleek. Do you have a link to more pictures? What about tinting the concrete? And if you did build a mold that was interlockable sideways like bricks then use a lighter weight material like hypertufa maybe for short walls? Could be good for making raised gardening beds?
Jul 30, 2009. 7:57 AMmadmanmoe64 says:
http://s1010.photobucket.com/albums/af223/madmanmoe64/Concrete%20Couch/
These are a few more pics I posted, You can see here how they interlock sideways.
Jul 29, 2009. 8:19 AMjbrecken says:
Your mold seems to have the same shortcoming that I noticed in the original. You seem to have the same spacing from the raised squares to the edge of the block as you have between the squares. If the outside margin was half the space between the squares, then you could stack your blocks in staggered rows, like a regular brick wall. Although it would mean you'd also need to make a mold for a half-size block if you wanted to make a rectangular wall, so maybe that's why you didn't do it that way.
Jul 31, 2009. 5:42 PMRichardBronosky says:
DUDE!!! I am going to do this to make a fire pit!!! I have been trying to decide how I wanted to construct it and I didn't see anything compelling. The custom concrete block design is awesome.
Jul 29, 2009. 8:26 AMmadmanmoe64 says:
We did consider this (lots of design meetings and eventually decided against it), but the idea was to make abstract seating arrangements and not a large brick wall. Plus (I won't explain why) offsetting the lugs in that way makes producing the molds more complicated.
Apr 28, 2011. 1:47 PMCam918 says:
This is unbearably cool. Tough for kids to play with, though...
Not to mention breaking your fingernails trying to pry them apart.
Mar 13, 2011. 7:10 AMMicioGatta says:
Great!!!!!!!!
Oct 28, 2010. 4:49 PMthepelton says:
One way I just thought of to make the pegs on the top and the sockets on the bottom slightly tapered would be to use paper cups to form them, since such paper cups are normally tapered from lip to bottom.
Nov 21, 2009. 8:41 AM13near says:
"4) Set aside for a few days or what ever the bag of the concrete states, in order for the ."
in order for the what???
Jul 28, 2009. 6:41 AMbeerboyone says:
After you pour you should pound on the outside of the form with a hammer. this would get a lot of the voids out and you'd end up with a smoother block. or use a concrete vibrator (vibrator for concrete not made out of concrete) if you have one.
Jul 28, 2009. 8:28 AMmikeasaurus says:
...also there are different types of concrete with various levels of aggregate, for a project like this (one that doesn't require much strength) you could use one with less aggregate which will also produce a smoother look.
But if nothing else, you must vibrate (tamp, hammer) your pour afterward.
Looks great though, super fun!
Nov 4, 2009. 7:11 AMhassi says:
Do a search for "papercrete."  Uses paper as an aggregate and reduces weight significantly.  There's a jillion recipes and your simple search will yield good results.
Green too:  Less concrete and waste paper (card board, corrugated, news print, cartridge paper, you name it...
A GRAND idea, these blocks...
Jul 29, 2009. 9:35 AMmasterfishslayer says:
"you could use one with less aggregate which will also produce a smoother look. " Or you could just use smaller aggregate in your concrete mix. You could also use a high performance / lightweight concrete mix to get the smooth look with a very high strength.
Jul 29, 2009. 6:24 PMMike__ says:
or you could use mortar/thinset which has no aggregate.
Jul 30, 2009. 6:26 PMservant74 says:
Finding lightweight concrete would work. Even the 'Sackcrete' has it. Or use pumice or vermiculite for the aggregate. You can also make the concrete 'greener' if you reduce the cement 10% and add the same amount of flyash. But it will also slow the hardening of the concrete. I have been doing some casting of concrete lately, lining the mold with 'rubber' and oiling (vegtable oil is a 'green' answer here) the forms helps. The rubber gives it a very smooth surface, if you use a mix that is a little more 'soupy'. (Don't just add water, ask your local concrete company about the chemicals they have that can help. If they are nice, they might sell you a little bit or give it to you.)
Aug 18, 2009. 9:43 AMtmr says:
I love it I got to try it out
Jul 30, 2009. 11:00 AMeblisster says:
You could add concrete dye to this process and have a bunch of brightly colored ones.
Aug 10, 2009. 7:04 AMthebriguy says:
Great idea. There are a lot of nice concrete stains out there to use.
Aug 8, 2009. 8:36 PMminerug says:
You should make inverted knobs on the bottom, so they work like lego blocks
Jul 28, 2009. 10:19 AMKiteman says:
LOL, I knew James may would find a way to cheat!
It would be more accurate if you pressed another wooden former into the concrete in the main mould, to make the brick hollow and stackable.
A whole wall of these would be awesome.
Aug 7, 2009. 9:20 AMWard_Nox says:
you know i bet you wouldn't need mortar if you did that
Jul 28, 2009. 2:09 PMlemonie says:
Oh crikey! You're not planning to build a wall with these then? L
Jul 28, 2009. 2:10 PMWard_Nox says:
why wouldn't he they'd be stable
Jul 28, 2009. 2:12 PMWard_Nox says:
...provided there are spaces for the studs
Jul 28, 2009. 2:52 PMlemonie says:
Yes, spaces for the studs. But it would be great to build a wall eh? L
1-40 of 92next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:GorillaGrill
