3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Concrete Lightbulb Wall Hook
Step 6Crack the lightbulb
Crack the lightbulb
  • last photo ←
Let the mortar mix cure for at least 72 hours. A few days more is a good thing.
This is the part where you are breaking up the lightbulb glass into little bits and pieces on purpose.
Glass will be flying in all directions, wear safety glasses and at least one glove (like in the pictures) at all times!
Over a trash can, hold the bulb in one hand that has a glove on it. I've tried to use gloves on both hands at this stage and didn't have the fine control I wanted. You might be able to do it.
Taking a hard metal object, start striking the side of the lightbulb. I'm using my carbride scribe. The glass with start to crack and form spider web fractures. Keep hitting. Eventually small pieces will fall and/or fly off of the bulb. When you have formed a good number of cracks around the bulb, take a toothbrush and scrub it vigorously over the entire bulb. . This will brush into the trashcan any glass grit or loose pieces.
Then take your carbide scribe (or awl or sharp nail) and start to pry up the edges of the glass left on the bulb. Some of it will come off in large chunks, some of it will come off a little piece at a time. Try to aim for the trashcan but know that it won't all go in there, some of it will pop up and go in any direction. If a large piece of glass doesn't want to come up and doesn't have any cracks in it, beat it with the metal object some more to create the spider web. Every so often take the toothbrush and rub down the lightbulb to get rid of any ground in glass or loose bits.
When all the glass has been removed from the lightbulb, take your scribe and carefully go around the neck of the bulb where the metal met the glass. Make sure there are no loose glass shards under the lip of the metal. Shake and tap the bulb to see what floats loose. When you are done, take a shop brush and run it over the entire bulb one more time to get any glass grit or loose pieces out of the holes in the concrete.
It's done! The mortar mix often leaves pits and holes even with all that shaking and tapping you did, but I think it adds a bit of character to the whole thing and makes each one you do unique. Feel the glossy smooth glass finish on the bulb and how it reflects the light. Now it's time to mount it!
32 comments
May 2, 2012. 8:12 PMstealthop says:
im fairly shocked you broke the glass off to be honest
Mar 28, 2011. 12:33 PMilike2make says:
Don't brush your teeth with that toothbrush.
Aug 31, 2011. 9:26 AMmrmerino says:
I heard glass dust was good for your tongue.
Nov 9, 2010. 4:46 AMMrSmoofy says:
Why is the concrete so shinny after the glass is removed?
Nov 10, 2010. 11:36 AMmadmanmoe64 says:
Cement is a fine powder and the cement mix will pick up the texture of whatever it is cast in. For example cement cast in a wooden box will pick up the wood grain.
When cast in glass like it is here, the cement takes the smooth texture of the glass, so it's nice and shiny
Aug 14, 2011. 8:56 AMxinistrom says:
so, in theory, the cement in a wooden box would look like a wooden cube?
Aug 14, 2011. 3:50 PMmadmanmoe64 says:
Apart from colour, yes.
It picks up the texture surprisingly well. If you ever see any buildings cast with wooden forms you could easily mistake the walls for painted timber.
http://transienttravels.com/wp-content/uploads/2008/09/p1000768.jpg
Aug 14, 2011. 8:22 PMjj.inc says:
Dude that's fawesome I wan't my house to look like that
Aug 14, 2011. 10:35 AMimBobertRobert says:
yes and no. hes saying that it would look like wood but not have the color of wood. if you made a face mold out of concrete (not saying you should, ouch) it would look and feel like your face, but it wouldnt have the colors. it might even have some hair, though :)
Aug 15, 2011. 8:42 AMxinistrom says:
ah, so it takes the texture of whatever its cast in?
Aug 15, 2011. 9:03 AMimBobertRobert says:
precisely!
Aug 14, 2011. 12:32 PMDemonSpawn says:
I see, I thought it was just a concrete filled bulb. Cool idea! might just make one this weekend!
Jan 27, 2011. 8:07 AMGrizzlyWizzly says:
Couldn't you leave the glass on the bulb? I thought that's what you were going to do when you started! The left-on glass might not be as fragile if there weren't bubbles in it that you could vibrate out like several people above said.
Awesome project, I might try it and try one with leaving the glass on if it's strong enough to resist breaking. (It should be if it's reinforced with concrete right? lol)
Dec 9, 2010. 6:25 PMGiesterfarher says:
Very Cool! I'm going to make a few of these in different colors, and use the ones I like most as Walking stick knobs.
Nov 9, 2010. 5:54 AMjoselezcano says:
After removing all the glass, the bulb was coated with varnish or something?
Oct 15, 2010. 8:30 AMbrianaemma says:
I've done a few concrete mold projects and I usually use vaseline to ease removal, but I will definately try the PAM teqnique now! Great Idea, Can't wait to try this project!
Apr 1, 2010. 9:47 AMvxir says:
Why crack the glass off?  Would it be fine for a doorknob or coat rack to just leave it there?  I would imagine that the crete inside would make it pretty tough... but I haven't tried this.
Also if you want to get the bulb glass without the screw on it, you can cut the glass neck of the bulb with a hacksaw -- the trick to stop the bulb from fracturing is to fill up a sink of water and cut it underwater.
Jul 19, 2010. 12:21 AMwetnap says:
The glass would inevitably crack under use, its not worth the risk.
Mar 27, 2010. 1:01 PMcancerious_17 says:
good one
Feb 18, 2010. 12:44 PMDoubleM says:
 so the glass isn't anymore on the lightbulb?
Jan 17, 2009. 7:48 PMminibah says:
I think that would make for a cool door knob
Jan 18, 2009. 9:09 AMBerkin says:
Yeah! How would you connect it in the door mechanism, though?
Dec 5, 2009. 11:38 PMBigUncleT13 says:
You would have to take a door knob, cut it by the wood of the door then cement that in instead of the bolt.
Dec 5, 2009. 11:53 PMBerkin says:
Hm, I'm not so sure that would work...
Jan 20, 2009. 8:52 PMProjectZro says:
cement in the square rod instead of the screw.
Jan 21, 2009. 6:17 AMBerkin says:
Oh, ok.
Sep 24, 2009. 9:55 PM3n16m4 says:
Have you tried rapidly heating and cooling the glass, to remove it? dropping a super-heated bulb into a bucket of ice water might eliminate a lot of the pain and time from the glass removal process.
Feb 27, 2009. 11:22 AMShane1163 says:
wow cool.. almost looks like a planet.. or a moon!
Mar 5, 2009. 8:32 AMneuromonkey says:
That's no moon!
Apr 11, 2009. 11:11 AMSpaceman-Spliff says:
...It`s a space station!
Aug 30, 2009. 10:05 AMbaslug says:
it's a trap!!
Jul 19, 2009. 10:08 AMgharo says:
my favorite things to do (i use plaster)but what i found it helpfull to vaccum the air out of the bulb i use my fridge compressor that i extracted ot of a used fridge found it on the street,also if u made the mix inside the bulb by fillng it with water then add concrete to saturation(without mixing) u get a marble surface with no bubles.
Jun 25, 2009. 6:49 AMOceanLady says:
If you put it in a strong, clear plastic bag - like a freezer bag or something - the glass won't fly around so much. I used to have to break glass all the time for some of the crafts I did, and that always made it make less of a mess.
Apr 22, 2009. 10:30 PMTechNerd1012 says:
to get all of the glass to come off from the metal base (or at least have it smooth), you could score the glass right at the base with a glass scorer/cutter. It will leave a nice smoth cut.
Feb 19, 2009. 9:48 PMbrokennye says:
Sweet! I had an idea. My mom use to use this vibrating jewelry cleaner that would vibrate the grime off her rings. I am not sure if they still make them....but if you were to set the cup with the light bulb in it with it on a couple of days it would probably get a lot of those air bubbles out. Just a thought.
Mar 5, 2009. 8:47 AMneuromonkey says:
I used a Hitachi Magic Wand'," set on low. It works amazingly well. For many things.
Feb 7, 2009. 6:34 PMacboothby says:
That is so cool. A very nice piece of art!! I love it. How much does it way?
Mar 5, 2009. 8:37 AMneuromonkey says:
The regular-sized bulb ones I made weigh 11.6 ounces. I also made some slightly larger ones that weigh exactly 1 pound. Here they are with the glass still on.
Jan 22, 2009. 10:42 AMUncle Staple says:
it looks like the moon. on the initial cracking you might try holding it inside a bag to prevent flying glass.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
80
Author:whamodyne
Named "Emblematic of the Instructables Universe" by the New York Times, I'm a maker and designer who enjoys looking at things sideways and playing with established form in new ways.
