Like yard decor that's a little different? How about making yourself some concrete mushrooms? They're inexpensive and easy!
WARNINGS: As with any project, you will need to take proper precautions. Read the safety instructions on the products and follow them. Quikrete can be rough on your hands, so be sure to wear gloves when working with it. Wear a mask and work in a well-ventilated area to avoid breathing in concrete dust or PAM spray. Wash your hands thoroughly when you've finished working.
Remove these ads by
Signing UpStep 1Gather your supplies
Supplies:
BOWLS for mushroom tops, sizes that appeal to you. Get a bowl with a nicely rounded (not flat) bottom interior. You can use any bowl that appeals to you esthetically. One of my bowls was plastic and the other was ceramic. I bought them at Goodwill very inexpensively. I wouldn't use a bowl that I plan to use for food later.
TUBE OR VASE for stem. (I used a Pasta Express tube..the kind sold on TV to quick-cook pasta, but you could use a vase or a paper tube. I cut the bottom off the Pasta Express so both ends were open).
PAM VEGETABLE SPRAY
1 bag QUICKRETE (1 made all 4 mushrooms with one 60 pound bag, but you will need less or more depending on the size of your mushrooms.) Available at home improvement stores like Lowes or Home Depot.
WATER (enough to mix into concrete).
MIXING SPOON strong enough to mix concrete
PLASTIC TUB to mix concrete in
PIECE OF PVC PIPE longer than your stem tube. (Available at home improvement stores like Lowes or Home Depot) Cut one end at an angle.
LANDSCAPE BLOCK ADHESIVE with CAULKING GUN -- (Available at home improvement stores like Lowes or Home Depot) comes in a tube like caulking.
ACRYLIC PAINTS -- The kind sold in 2 oz. bottles at craft stores like Hobby Lobby or Michael's. (example: Creamcoat or Americana)
PAINT BRUSH
SEALANT -- I used Daichcoat sealer, but you can use your choice of sealer. Consider whether you want a flat finish, medium gloss or high gloss to your finished mushroom.
The tubes for the mushroom bases I use are hard plastic, and they're about 3 inches across. I use PVC pipe (like for plumbing) down the center of the plastic tube (mushroom base). After you've filled the tube with Quickrete, you push the PVC pipe into the concrete. You can either push it straight up and down or you can tilt it at a slight angle. I say slight angle because if you put it at a steep angle, your mushroom will look like it's falling over.
You can also create a bit of an angle by pushing the PVC into the ground at a slight angle when your moshrooms are completed and you are placing them in your garden.
A bit of advice on the stepping stones...they need to be about 1-1/2 to 2 inches thick or they'll break when you step on them. Also, for stepping stones, you want fairly straight up and down sides so the thickness is the same clear to the edge. I have used cake pans from Goodwill for stepping stone molds. BE SURE to spray them with PAM before putting the concrete in. I didn't use PAM when I trued to use this cute dimensional lamb cake pan to make a little lamb for my memory garden. I never did get the concrete lamb out of the pan, it was TOTALLY stuck! Have fun!
But be careful when you paint them don't paint the inside of the bowl unless it's a non toxic paint to birds .....
I made sure it was thick enough so it would hold up. They sell a liquid concrete bonding agent at Lowe's that I might mix in with the concrete if I were doing another bird bath. The bonding agent (about $6 for a quart) does strengthen the concrete.
I pushed some colorful marbles into the wet concrete on the inside of the bowl to give it some sparkle. Then, I let it set for several days to dry and cure before pulling it out of the soil and mounting it on a tree stump.
I just used a hose to wash the dirt off the outside of the bird bath.
I would probably embed some chicken wire into the concrete to help reinforce the table top.
I see two problems, however. First, of course, is that it would be extremely heavy. Second, the mushroom top is rounded (like a dome) not flat, so you couldn't really set anything on the table without it falling off. BUT, if you do make a mushroom table and stools, I would enjoy seeing photos! Have fun.
I wanna make that now, see how many people try to kick it
