3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Concrete Mushrooms -- Yard Art
Like yard decor that's a little different?  How about making yourself some concrete mushrooms?  They're inexpensive and easy!
WARNINGS:  As with any project, you will need to take proper precautions.  Read the safety instructions on the products and follow them.  Quikrete can be rough on your hands, so be sure to wear gloves when working with it.  Wear a mask and work in a well-ventilated area to avoid breathing in concrete dust or PAM spray.   Wash your hands thoroughly when you've finished working.
Step 1Gather your supplies
Supplies:
BOWLS for mushroom tops, sizes that appeal to you.  Get a bowl with a nicely rounded (not flat) bottom interior.  You can use any bowl that appeals to you esthetically.  One of my bowls was plastic and the other was ceramic.  I bought them at Goodwill very inexpensively.    I wouldn't use a bowl that I plan to use for food later.
TUBE OR VASE for stem.  (I used a Pasta Express tube..the kind sold on TV to quick-cook pasta, but you could use a vase or a paper tube.  I cut the bottom off the Pasta Express so both ends were open).
PAM VEGETABLE SPRAY
1 bag QUICKRETE (1 made all 4 mushrooms with one 60 pound bag, but you will need less or more depending on the size of your mushrooms.)  Available at home improvement stores like Lowes or Home Depot.
WATER (enough to mix into concrete).
MIXING SPOON strong enough to mix concrete
PLASTIC TUB to mix concrete in
PIECE OF PVC PIPE longer than your stem tube.  (Available at home improvement stores like Lowes or Home Depot)  Cut one end at an angle.
LANDSCAPE BLOCK ADHESIVE with CAULKING GUN -- (Available at home improvement stores like Lowes or Home Depot)  comes in a tube like caulking.
ACRYLIC PAINTS -- The kind sold in 2 oz. bottles at craft stores like Hobby Lobby or Michael's.  (example:  Creamcoat or Americana)
PAINT BRUSH
SEALANT -- I used Daichcoat sealer, but you can use your choice of sealer.  Consider whether you want a flat finish, medium gloss or high gloss to your finished mushroom.
22 comments
Aug 28, 2011. 11:08 PMsilverlace says:
if you used a pvc pipe down the centre of the stem, added the concrete around it, it would be lighter, but probably still strong enough to hold the top. if you took a can a little larger than the stem, and set it in the top, spraying it with pam first, it should also make the top lighter and sit well with the stem, don't you think? i am definitely making some of these when i get the chance. i also think if you used some kind of "filler" to the concrete, anything lighter you have laying around, it would make it lighter, but possibly still strong enough, if you use the bath technique.
Jul 7, 2011. 2:47 PMmikesnyd says:
The best way to tell if your concrete has set up the right amount is with your fingernail or a screw or nail of sorts. Scratch the surface of the concrete (in this case it is the bottom of the shroom) If it really digs in easy it is not fully cured. Wait until it feels hard to scrape. Also your can drape a small plastic tarp over them and place a small space heater on the lowest setting to speed up the cure. After it come out of your mold if you are in no rush to paint your yard at you can fully submerge the pieces in a five gal pail for 28 days. If you do this the concrete will come out the hardest it possibly can providing you added the correct amount of water when you originally mixed it. Concrete is such a fickle and funny thing. It wicks the water off when cured for 12 - 24 hours and requires more water to continue the curing process for the rest of the 28 day period.
May 30, 2011. 9:28 AMprecious11 says:
Love them. I'm off to try and make them now!!
Feb 14, 2011. 5:13 AMturbotonic27 says:
haha,nice :P
Mar 27, 2010. 10:58 PMsuezq says:
This is a well done 'ible and I think I'll give 'em a try. I attempted to make a large stepping stone from the top of one of those plastic deli meat trays but didn;t have a clue what I was doing. Your 'ible explained it to me in plain english. First mix the quikrete properly, then spray the mold, then be patient (which I wasn't), then more patience and finally more patience! I can't wait to try all sorts of bowels and tubes. When you say you can use the pipe to make them tilt, can you explain that a bit better to me? Is the tube you're using flexible?
Mar 28, 2010. 1:24 PMsuezq says:
Thank you. Now I even more curious about your memory garden! Can you send me a picture of it if I send you my e-mail address, or post it on your website? Oh and just so you know, I was up until 1 a.m looking at everything on Etsy. Now I have another addiction! LOL. Thank you for your great ideas and neat website.
Mar 24, 2010. 4:25 AMfretted says:
If you get some pretty big bowls and just line the sides on the inside of them you could make some real nice birdbaths too !
But be careful when you paint them don't paint the inside of the bowl unless it's a non toxic paint to birds .....
Mar 25, 2010. 2:01 AMyodaandmoody says:
pretty cool Do you think I could make a mushroom top table and mushroom stools using this method?
Mar 25, 2010. 4:42 PMBadVanGoh says:
might get a tad heavy and not liftable by normal means
Mar 24, 2010. 2:36 PMstarshipminivan says:
I use wet sand to create a cap mold to get custom shapes.  If you press stones, shells, etc. into the sand a little before loading in the concrete, it will become part of the surface of the cap.
Mar 23, 2010. 9:54 PMliggy says:
Nice!  My mom's got these in her garden at her cottage, only difference is she dug a hole in the ground, placed a plastic bag in hole. filled hole with concrete, and then stuck a birch tree branch (obviously fairly thick, in as the stem.  I like the birch bark stem look, but like your uniform shroom heads.
Mar 23, 2010. 10:12 AMchaosrob says:
Very Nice. I'm gonna make some and let the kids paint and place them.  Heres an 'upgrade' idea. Put the PVC all the way thru the 'stem' and hang about 1 inch on the top and whatever you want as the steak on the bottom. And in the 'mushroom cap', center and sink a PVC end cap or coupler (that fits your thru pipe) that you drilled thru the sides and put a length (or two) of a wire hanger thru, bend it a little for stability, making sure that the angle of the stem-PVC matches the caps-PVC. This will allow you to swap caps, disassemble, etc. I personally will be using a coupler that I sanded the 'stop' out of the middle so it's deeper, for more support.
Mar 23, 2010. 8:52 AMrimar2000 says:
Very nice!
Mar 23, 2010. 7:47 AMHolly E. says:
 I almost lost my whole paycheck to the metal ones in Lowes. I am going to try to make these if I've got any leftover concrete. Also I will have to remember that I can use PAM as a mold release for concrete. Great instructable.
Mar 23, 2010. 5:40 AMPlasmana says:
This is a really cool idea, Ill deffo try make those soon!
Mar 23, 2010. 1:57 AMKryptonite says:
Must. Make. Mushroom ring.
Mar 22, 2010. 6:12 PMCaseyCase says:
 Very nice instructable but a concrete-filled soccer ball is the best yard art in my opinion.
Mar 23, 2010. 12:03 AMcraig3 says:
and painful to some unknowing people haha
I wanna make that now, see how many people try to kick it
Mar 22, 2010. 6:04 PMzascecs says:
Great idea; I've always seen these in stores, but now I can make my own!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:THYMETOCHAT
Married, 2 grown children, 3 grandchildren and one beautiful German Shepherd. I enjoy new projects and am always willing to take on a challenge...be it building a worm composting bin, taking parts fr...
more »
