Step 12"Plant" Your Mushroom
3 Simple Ways to
Share What You Make
Other ways to share:
Make a Moss Mushroom: Yard Art
by
GardenGirl007
28 Upcycles for the Garden
by
sparkleponytx
Easy to make concrete bowls and planters...
by
WUVIE
MAKE A SLATE ROCK BENCH FOR 3 DOLLARS!
by
sunshiine
Trash to yard art or thinking outside the box
by
l8nite
Make An Oasis In Your Front Yard!
by
Creativeman
Leaf Castings
by
GardensAndCrafts
Restoring a Garden
by
crudworks
How to start your very own Garden Giant Mushroom Patch!
by
Brenpat
© 2012 Instructables
All Steps Viewing
The tubes for the mushroom bases I use are hard plastic, and they're about 3 inches across. I use PVC pipe (like for plumbing) down the center of the plastic tube (mushroom base). After you've filled the tube with Quickrete, you push the PVC pipe into the concrete. You can either push it straight up and down or you can tilt it at a slight angle. I say slight angle because if you put it at a steep angle, your mushroom will look like it's falling over.
You can also create a bit of an angle by pushing the PVC into the ground at a slight angle when your moshrooms are completed and you are placing them in your garden.
A bit of advice on the stepping stones...they need to be about 1-1/2 to 2 inches thick or they'll break when you step on them. Also, for stepping stones, you want fairly straight up and down sides so the thickness is the same clear to the edge. I have used cake pans from Goodwill for stepping stone molds. BE SURE to spray them with PAM before putting the concrete in. I didn't use PAM when I trued to use this cute dimensional lamb cake pan to make a little lamb for my memory garden. I never did get the concrete lamb out of the pan, it was TOTALLY stuck! Have fun!
I would probably embed some chicken wire into the concrete to help reinforce the table top.
I see two problems, however. First, of course, is that it would be extremely heavy. Second, the mushroom top is rounded (like a dome) not flat, so you couldn't really set anything on the table without it falling off. BUT, if you do make a mushroom table and stools, I would enjoy seeing photos! Have fun.
