3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Concrete Paver Floor
I wanted a concrete floor in my shed but the shed was at the back of our property and up a hill
  No way to get a concrete mixer back there
  I didn't want to push a wheelbarrow back and forth
  I didn't want to pay for a concrete truck and cement pump
  And I wanted to do it an hour or so at a time, if it took a year it didn't matter
  And I had to use the shed during that time...
So I decided to pour cement pavers and stock pile them until I had enough for the whole floor and could lay them.
You'll notice from some of the following photos that my shed is a little unusual
Step 1Build a Form
Build a Form
 The first step is to build the form for the pavers. My design for this was based on the amount of concrete an 80 pound bag of premix would make. It ended up being 22" square and the concrete came up to ~1 inch below the top of a 2x4.
 For my shed I needed nearly 30 pavers of this size. For the first 10 or so I made a form that held a single paver but when that form needed to be replaced I built one that held three. Both of these forms had issues, I would build forms of two next time. The single was slow and the triple was VERY heavy to turn over and the middle paver was hard to get out.
 I also found a float handle and screwed a bit of plywood to it for flattening off the pavers... any bit of wood would work just as well.
3 comments
Nov 4, 2009. 12:24 PMlemonie says:
Can you imagine concrete jigsaw pieces? At the moment that's the only thing I can think of that would have made this better.
L
Nov 5, 2009. 9:44 AMfritsie123 says:
Wow! Could that be done? That would be so utterly amazing!
Nov 5, 2009. 9:53 AMatombomb1945 says:
You could make the forms out of thinner wood or even plastic (probably better).  You would have to do a minimum of four at a time in a 2x2 configuration with the pieces interlocked.  It would take some doing, but it could be done.
Awesome idea pouring your own bricks.  Better than trying to purchase them a two to three bucks a piece.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:markbyounger
